hood gap? - Ford Truck Enthusiasts Forums
hood gap?
Old 08-13-2014, 12:32 AM
mcali2's Avatar
mcali2 mcali2 is offline
mcali2 is gaining momentum as a positive member of FTE.mcali2 is gaining momentum as a positive member of FTE.
hood gap?
OK what size gap do you have on your hood? the area between the hood and the body not the fenders. I have shimmed mine out far and still only have 1/8'' and it binds up bad. I have shimmed the hood up and out. the bolts are all the way adjusted to the front. I have arched the hood to reshape it and still can't get it to open with out binding. The hinges look good.
Old 08-13-2014, 01:45 AM
cyclone-429's Avatar
cyclone-429 cyclone-429 is offline
cyclone-429 is starting off with a positive reputation.
Here is mine... Its about 1/8" near the fender, then opens up to 1/4" near the center vent. It is also high in the middle.
Obviously its not as well aligned as yours, but it works.... Kinda. I never noticed it before, but if I open it slowly, it binds just a bit, but if I open it normally, it opens right up.
Old 08-15-2014, 08:20 AM
mcali2's Avatar
Anyone else own a truck and tape measure here? anyone have a hood that does not bind up when opening? I need your measurements.
Old 08-18-2014, 01:36 AM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
Yours seems a little tight. Mine is 3/8"
Old 08-19-2014, 01:33 AM
oldebrush's Avatar
oldebrush oldebrush is offline
oldebrush is starting off with a positive reputation.
hood gap?
Mike, Maltman may have a bit too much gap in his, but I would think 1/4" should work well. I don't have my hood ready so I can not take measurements, I have to replace the rear inner support piece that someone in the past thought to jump on, or something. I have a straight piece from a hood that was rusted on the front, so I am good, just have to make the change. I will be shooting for a 1/4" gap on mine.
Also, I plan to weld up and restore the holes the hood springs go in. Mine are worn fairly deep. How are yours?
Aloha, you have been a big help, thanks.
Old 08-19-2014, 02:19 PM
Maltman's Avatar
Sounds right Tony, the gap closest to camera in pic is actually 1/4", but opens to 3/8" in the center and caries that over thru the passenger side...whats funny is the "ridge" on passenger side of hood looked like it rubbed on cowl and maybe PO adjusted out to 3/8"...hope THAT helps and doesn't add to the problemo!!
Joe
Old 08-19-2014, 11:29 PM
mcali2's Avatar
I guess I will have to cut a slot to move the hinge further forward. It is all the way out and the hood is adjusted all the way out too. or maybe modify the hinge plate?
Can anyone identify this step van for me? Jim Collier 1947 and Older Ford Trucks 11 11-17-2015 06:05 PM
LOOK BETTER? Bud Mud 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 08-03-2015 07:52 AM
What is this fuse ScrewIN Electrical Systems/Wiring 10 12-08-2014 04:41 AM
Almost 2 cords wood in truck jesse24spd Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 11-15-2014 10:45 AM
truckdrivers F-150 adventure truckdrivermn 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-18-2014 10:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
