Hey, I am swapping axles on my 1989 F-250 from 4.10 to 3.55. It has a ZF 5 and BW 1356 transfer case. The tires are the stock 235 85 16. What speedometer gear do I need for the 3.55 gears?
you will need to figure out how far off the speedometer is, then adjust the gear sizre by that. every 2.5 mph it is off at 55-60 mph equals one tooth on the cable gear.
if it is reading fast, add a tooth, if it is reading slow, take a tooth off.
