Need new radiator for 49 F6 V8
From my expereince, recoring is the same price range as the cheaper new flathead radiators (~$400). With the new radiators, they don't always come with the mounting holes in the right spot, fit exactly etc, but if you get yours recored, you eliminate a lot of those uncertanties while retaining the stock look. Plus you will build a relationship with your local radiator pro who could help you down the road should there be an issue. They can also help you boil out your fuel tank etc.
The local radiator guy is famous for boiling them out, repainting them, and returning a leaky radiator.
I would have to take half a day off of work and drive 50 miles four times to get it repaired.
I can try to get a quote later this week. I do agree with your sentiments however.
I am not quite sure that a F1 or F2 radiator is as large as a F6s. I do belive that it would work if need be.
hotairballoonpilot
10-16-2018 08:35 AM
aussiecowboy
09-10-2012 07:00 PM
