pulsating brakes - Ford Truck Enthusiasts Forums
pulsating brakes
Old 07-12-2003, 01:07 AM
elkslayer1 elkslayer1 is offline
elkslayer1 is starting off with a positive reputation.
pulsating brakes
I am a proud PSD owner, but i have been having problems with my brakes(front) pulsating during braking @ about 70-50 mph. Now, what i found out is the rotors keep warping and i don't know why, i have been driving for along time, and have never had this problem before with any other vehicles. The dealer(lol) says i am either towing a big load or am riding the brakes and insists that it is my rear rotors that are bad. it is neither, after i replaced the front rotors the pulsating went away, OH! did i forget to mention that i had the rotors turned twice and than replaced and turned again before i did the job myself and replaced the rotors a second time? The dealer sucks and wants to keep charging more for a problem that never goes away. I think it is a dfective part but i can't narrow it down. Has anyone else had this problem? Or can give some advice? I would appreciate any input. THANKS!
Old 07-12-2003, 06:01 AM
the tiler the tiler is offline
the tiler is starting off with a positive reputation.
pulsating brakes
Im Having the same problem I have a 2002 F350 only 25000 miles
and the front brakes stink.
Anyone think this would be under warrenty I dont tow anything or carry alot of weight
Thanks
Jason
Old 07-12-2003, 07:56 AM
theologian's Avatar
theologian theologian is offline
theologian has a good reputation on FTE.theologian has a good reputation on FTE.theologian has a good reputation on FTE.
pulsating brakes
The problem is the Ford Motor Company. They are cheaping out on rotors - no longer can you get high mileage with the brakes, you get the cheapest bit of junk they can find and call rotors.
The post '99 have worse brakes than the pre, though both are a lot worse than the earlier trucks. I have been told that a cure for the problem is after market rotors, if you can find any rated for the wieght.
Theo
Old 07-12-2003, 07:20 PM
pulsating brakes
mine started at 9000 miles, Now i have 86000 and still the same problem, WHAT IS UP WITH THAT? since then i have installed aftermarket rotors myself, I dont have the brand off hand but i'll let you all know later. The rotors are about the easiest to replace as is the pads. I run just under $400 to do the job myself. "Thats rotors and pads on all four feet." What a savings from having the dealer do it at $800 just for replacing the rears and turning the fronts!
Old 07-13-2003, 01:26 AM
Jerrybo66's Avatar
Jerrybo66 Jerrybo66 is offline
Jerrybo66 is gaining momentum as a positive member of FTE.
pulsating brakes
For what it's worth.......
I also had trouble with the front brakes.... They were dragging and showing brake dust on the wheels... I replaced calipers and pads thinking the pistons were sticking...Still had brake dust..The extra heat caused the one rotor to warp.. I wrote to another forum and the answer I got was to replace the front hoses... Though it sounded weird, I did it 'cause I had no other idea to try. But thinking about it, it made sense...If the inside of the hoses were comimg apart, acting like a check valve it could leave a little bit of pressure on the pistons, causing a little brake drag...After installing them I noticed the wheel spun more freely....It may sound like nonsense, but it worked...No more brake dust, no more warped rotors so far....
Old 07-13-2003, 01:42 AM
pulsating brakes
I'll certainly look at that, i'm thinking it is probably something simple (hopefully)! Thanks.
Old 07-14-2003, 12:15 AM
baddsuperduty baddsuperduty is offline
baddsuperduty is starting off with a positive reputation.
Thumbs down pulsating brakes
If theres one problem that plagues our great big PSD's its brakes.
The truck is so heavy then put a trailer behind it and wallah, warped front rotors. I deal with this problem day in and day out.
The only cure is high performance aftermarket pads and rotors and if you do pull a trailer get electric brakes for it if poss. There are several places to get these aftermarket rotors and pads even cryogenically treated rotors will help. If you need help in finding where to get the right products I can tell you where I get them.
Good luck!
Old 08-18-2003, 06:12 AM
Paige Haddock's Avatar
Paige Haddock Paige Haddock is offline
Paige Haddock is starting off with a positive reputation.
pulsating brakes
"Baddsuperduty" wrote that if anyone needed to know where to get good aftermarket brake parts, just ask. I, too, have had problems with the brakes on my 2000 F350 4X4 dually. A good brake shop that I've trusted for years tells me that they have alot of problems with these big trucks. They have turned the rotors twice now in two months, replaced the pads twice, and the pulsating is coming back, just two weeks later. I haven't pulled any trailers or hauled a load in that time, either. If I can replace the rotors with quality aftermarket, I'll do it immediately. Just need to knw where to get them. I'm in Houston, Tx.
Thanks for your help....
Old 08-18-2003, 02:48 PM
Dan Ward Dan Ward is offline
Dan Ward is starting off with a positive reputation.
pulsating brakes
Hey Elkslayer
I have a questions about brakes but that comes later. From your name I'm assuming you're an elk hunter. I'm from MN and have been hunting in unit 16A since 1988. We've had great success hunting the early season. Once you've experienced bugling a bull in any other hunting experience that I've had pales. I've seen a little rain on the radar, but I'd like to know what your read is on the fire/dryness outlook. Also what do you hear about this years herd. We're getting pretty close (3 weeks) to loading the horses and heading west.
Back to the less important brake issue. I actually bought my 2000 7.3 Excursion 4X4 LTD, to replace my brother in laws 96 PSD, so we would have a newer vehicle to pull the horses out. My question is: with the 4x4, do the hubs need to come off to remove the rotors and pads. I'm thinking of replacing them myself also. Do you have any tips you'd offer about doing the job yourself?
Any feedback - especially about the elk - would be appreciated.
Dan Ward
Old 08-19-2003, 10:41 PM
pulsating brakes
Hey Dan, First of all right on with the elk hunting! 16A sounds like the wilderness area. don't know much about it, there are fires in that area but i think the cooler weather with any luck will help our fire fighters.I think you will be ok! its traditional to have fires here, but that doesn't stop the hunting season, just be safe and smart! we have had yet another mild winter, so i suspect the herds will be in great numbers again this year! GOOD LUCK!
Now on to the rotors, thats a bad deal with alot us. i did the rotors and pads myself and it could'nt of been easier! Assuming the excursion is identical to the pick-up trucks it is not necessary to remove the hubs, once you have removed the caliper and bracket, you can then tap the rotor off. it is a very simple procedure you won't believe it! 1/2 hour for the other side! I would do them myself and save your money for that hunting trip! Rotors and pads roughly $250 and your time vs $800 at the dealer .
Old 08-20-2003, 12:39 AM
pulsating brakes
A great place to get high performance brakes is a company called EGR. They are out of california and they are very nice to work with. Awesome results with their systems. Call Glenn at 1-800-468-2279. I've installed several sets now and so far everyone is very happy. Good luck and yes the brakes are very easy to install.
Old 08-20-2003, 03:35 PM
sfsterling sfsterling is offline
sfsterling is starting off with a positive reputation.
pulsating brakes
Paige, I have been told by serveral technicians NOT to get the rotors resurfaced if they are warped and to buy new ones. They say while the resurfacing them fixes the problem temporarily it also take metal off the rotor leaving less metal to displace heat making them more prone to warp.
I was also told by several techs NOT to buy the lifetime warranty brakes at midas as they cause accellerated rotor warp beacuse the material they are made out of does not displace heat and is hard on the rotors. What good are lifetime warranty brakes if you have to replace the rotors every 20K?
Old 09-12-2003, 12:06 PM
paradiddle's Avatar
paradiddle paradiddle is offline
paradiddle is starting off with a positive reputation.
pulsating brakes
Went through the same deal after towing my buddies (non brake) trailer to Fla. from NH. I had bought cheapo new rotors and pads before the trip. I remachined them but it came back after a month or so. I now tow a electric brake trailer and am getting a set of Raybestos pads and rotors this time. Hope it works better.
Old 09-13-2003, 12:12 AM
Michael013 Michael013 is offline
Michael013 is starting off with a positive reputation.
pulsating brakes
We never resurface. Just buy new ones, heavy duty rotors if you can afford them. Rotors are one part I would not buy from the Ford Dealer, for any Ford vehicle.
Old 09-14-2003, 04:54 AM
Phat02 Phat02 is offline
Phat02 is starting off with a positive reputation.
pulsating brakes
Dan Ward and elkslayer1. i see that you are both avid hunters.
check this out, i thought it was funny.
http://www.bumperdumper.com/bumper2.htm
Need Brake Hlelp/Advice RobRoss Excursion - King of SUVs 13 05-29-2015 08:13 AM
How To Fix Pulsating Brakes pawpaw Ranger & B-Series 0 07-08-2014 07:03 PM
Any GOOD 2wd rotors available? Rory428 Ranger & B-Series 11 07-08-2014 09:35 AM
ABS Light Comes On & Brakes Pulsate - 1998 Expedition mikulskn 1997-2006 Expedition & Navigator 7 06-26-2013 11:23 PM
Brake update... X_Hemi_Guy Excursion - King of SUVs 30 07-06-2009 12:50 PM
Tags
1998, 2001, 2004, 99, abs, brake, brakes, excursion, explorer, f150, f250, plusing, prevent, pulsating, stopping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
