Best Place in DSM Area for D44 TTB Alignment. - Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
Old 08-12-2014, 09:06 PM
Z3T3C Z3T3C is offline
Z3T3C is starting off with a positive reputation.
Recently did a front end rebuild on my '94 F150 XLT 4x4. Put Moog K80818 adjustable camber/caster bushings in when did ball joints. Short story most Firestone employees that I have encountered are a bunch of incompetent asses who probably shouldn't touch a vehicle let alone handle a wrench. You can see my original thread here: http://www.ford-trucks.com/forums/13...l#post14578219
Thinking about going to Dewey Ford tomorrow. That is unless anyone knows of any solid alignment shops in the DSM area that can actually do a decent job at aligning our Fords with TTB?
Old 08-12-2014, 11:36 PM
twigsV10's Avatar
twigsV10 twigsV10 is offline
twigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to behold
This is a question I'd like to know as well, no one seems to understand how these front ends work. I gave up on my 94 and did it myself for years, put 100k on the truck and never had a front tire wear unevenly and drove perfect. This isn't the best answer for every one as it takes a good deal of time and knowhow. The TTB isn't a bad front end if setup correctly.
Old 08-13-2014, 06:16 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Seek out the shops that only do alignments, they have to know what they are doing or they go out of business. The tire sales shops many times aren't as good. I never had any actual alignment work done in the DM area, so unfortunately not a lot of help. I know a shop in Coralville that can...
Alignment specification 84 F250 Filko 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 01-15-2015 01:46 AM
Pwer Assit vs Power steering dsm8 1973 - 1979 F-100 & Larger F-Series Trucks 26 11-02-2014 02:03 PM
HOWTO - TTB (Twin Traction Beam) Frame Bushing, U-Joint Replacement, etc. ctubutis '80-'86 HOWTO's 0 02-08-2011 09:14 PM
78 F150 w 400M - Block Huggers dsm8 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-22-2010 07:50 AM
Electrical Problems 2003 Nav Lemgomez 1997-2006 Expedition & Navigator 6 08-30-2010 06:37 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
