Has anyone tried Champion 7989 plugs - Ford Truck Enthusiasts Forums
Old 08-12-2014, 09:39 PM
wattsup wattsup is offline
wattsup is starting off with a positive reputation.
I want to change plugs in my '06 f150, it has the 5.4l engine, with 86k miles. I believe they are the original plugs.
I was wondering if anyone can give me some feedback on the Champion 7989 plugs?
Which plugs do most of you guys recommend?
thanks
Old 08-13-2014, 03:00 PM
cb_13's Avatar
cb_13 cb_13 is online now
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
My recommendation is if you plan on keeping the truck long enough to change the plugs again consider the Champions. If not use Motorcraft. The Motorcrafts are cheaper and seem to be the best performing in the 5.4 3 valve. I have seen mixed reviews on the Champions some have had great luck with them, others have had to change out some or all due to misfires. The 1 piece design eliminates the breakage issue if you do replace them again though. FWIW I used Motorcraft for my truck.
Old 08-13-2014, 03:10 PM
Going back with Motorcraft plugs seems to be what I have been hearing from other sources I have talked to.
Thanks for the advice CB 13. That's probably what I will do too.
Old 08-15-2014, 03:43 AM
Fordz-r-us's Avatar
Fordz-r-us Fordz-r-us is offline
Fordz-r-us is starting off with a positive reputation.
I installed the Champion 7989 plugs in my '06 FX4 in December 2008. They're still in there and it runs perfect.
I haven't been following this issue much lately, but I think I read something about a redesigned Motorcraft plug that is either welded, or one piece or otherwise made to not separate. If that's true, it would be a lot cheaper way to go than the $12 each I paid for the 7989.
Old 08-15-2014, 04:26 AM
cb_13's Avatar
The redesigned motorcrafts are still a two piece. They're a double platinum and I have heard the heat range is different to help with the carbon build up.
Old 08-15-2014, 08:13 AM
Thanks for the feedback. I will check into the motorcraft plugs. That's probably the way I will go.
Champion 7989 Spark Plugs svt2205 2004 - 2008 F150 37 12-11-2016 05:51 PM
5.4 spark plug replacement??? 's dentfxr Modular V8 (4.6L, 5.4L) 6 08-10-2013 07:51 PM
Champion 7989 rodinator1234 2004 - 2008 F150 15 08-14-2010 09:48 PM
Latest Spark Plug TSB #? 428fourby 2004 - 2008 F150 10 09-14-2008 05:53 AM
5.4L Champion Plug Gap motown 2004 - 2008 F150 4 07-06-2008 10:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
