Got a lotta ignition noise in my radio - Ford Truck Enthusiasts Forums
Old 08-12-2014, 09:26 PM
Skalywag Skalywag is offline
Skalywag is gaining momentum as a positive member of FTE.
Does some one still make a suppression device or do I need to put a condenser on it somewhere? running 12v and 226 cu in.
I don't like the tvrs wiring.
Old 08-13-2014, 01:35 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
I never found a suppression device that worked any better than a condenser.
I would put them on the Alt, Coil, Wiper Motor and anything else I thought
needed it. But good new well insulated wiring helped the most. If you have the old cloth
covered wire that is loosing insulation it may well be a lot of your problem. But
for sure do the condensers as they will help also and are cheaper than a rewire job.
Old 08-14-2014, 04:48 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
Get radio suppression spark plug wires.
Old 08-14-2014, 09:17 PM
Thanks for the replies, but I forgot to mention that I only get the static when it is on AM. There may be no cure. However there are still al lot of AM stations that play cool music.
Old 08-14-2014, 11:52 PM
hooler1's Avatar
hooler1 hooler1 is offline
hooler1 is gaining momentum as a positive member of FTE.
Quote:
Glad to hear someone likes AM. I do too! The replies above are correct, condensers are good, and radio suppression wires are important. But one thing to really look at close is the ground of the antenna itself. Make sure that the antenna mount is making a good, tight, reliable electrical connection ground to your body sheet metal. (The body sheet metal is actually 1/2 of your antenna system.) Next run a good ground wire from the metal radio case to again somewhere on your sheet metal such as the firewall. Now you should also check to make sure the grounds on your truck all connect to a common point. You should already have the negative cable from your battery grounded to your engine block. From this point on your engine block, if you do not already have one, add a ground from the engine block to a good tight connection on the firewall, also from the ground point on the engine block run another ground to the frame. This makes your engine block the main grounding reference point. Auto parts stores sell braided "ground strap" in their Dormann HELP parts section. Buy two of those for the block to the frame, and block to the sheet metal connections. Now we'll have all the grounds common to each other, so not only should you have better radio reception, but also less voltage drop to everything that is grounded to the frame or the sheet metal such as lights, wiper/heater motor, gauges, etc. Next also check to see if the radio has an antenna trimmer adjustment near the antenna jack in the back. If so, after all the grounding has been checked and repaired, you just dial in a weak station towards the top of the dial, and adjust it for best reception. Now after all of that, if you still have noisy AM reception, there is one more thing you can do. Upgrade your ignition system and replace your points with a Pertronix electronic points eliminator system. I put one of those in my truck and I could not believe the difference in AM radio reception. Pretty much eliminated the iginition nose. And it made the engine run better too! It's less than $100, but well worth it because of the radio and engine performance improvements it made for me. Hope this helps!
Old 08-15-2014, 01:21 AM
'50'sFever '50'sFever is offline
'50'sFever is starting off with a positive reputation.
pertronixs noise reduction...
...I second, third, fourth & more the motion on that Pertronix or similar Mallory units. One of the best things since sliced bread & all that. But, carry old points parts & if you notice a dead ignition skip/miss, order a new one, cause it's getting ready to go. Had 'em last 20 yrs, some 5. jh
69 Bronco Vinford 1966 - 1977 Early Broncos 2 04-21-2016 12:27 PM
Wanted Truckin23 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-06-2014 09:20 PM
delete Myfreeford 1973 - 1979 F-100 & Larger F-Series Trucks 36 08-17-2014 10:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
