1992 F-250 Differential Fluid Change
WHAT FLUIDS DO I NEED TO PUT IN MY FRONT AND REAR DIFFS ON A 1992 F-250 4X4? HOW MUCH IN EACH? HOW MUCH FRICTION MODIFIER? I'M NOT SURE WHICH DIFFS I HAVE? CAN ANYONE HELP ME? WHAT SHOULD I USE FOR HYPOID? WHAT IS HYPOID? IS THERE A COMMON NAME FOR IT? PLEASE HELP. THANKS
Both of you can find all that info & more in a Haynes manual.
"Hypoid" gears are spiral-cut. They're much stronger & quieter than "bevel" or "spur" gears whose teeth run straight, but they all use the same gear oil.
This page shows how to tell if you have a limited slip - only GMs have "posi"s.
BTW Calvin - turn off the ALLCAPS.
Camper Special Gene
04-16-2014 05:05 PM
BCO2JCO
04-09-2007 09:55 PM
Dave85zxt
08-24-2004 11:35 PM
