360 water pump replacement
Simple as dirt.
Fan/pulley held on by four bolts. Remove any brackets and hoses, four bolts attach pump to block.
Be sure to replace the water by-pass hose now. Once the pump is on you can't remove it. It's 5/8" heater hose.
Here's the by-pass hose. Replace now. If it goes bad later, you have to remove the pump to change it.
WATER BYPASS TUBE, NIPPLE SBF, BBF, 351C, 351/400M & FE - Alex's Parts Sales
They have them for around $5.00
I see them on e-bay, made out of stainless steel, for around $20.00.
EDIT: Here's a link the the stainless steel version:
http://www.ebay.com/itm/304-Stainless-Steel-Water-Bypass-Tube-Nipple-Ford-Mercury-Sbf-Bbf-Fe-351c-/141371516782?pt=Motors_Car_Truck_Parts_Accessories&hash=item20ea66276e&vxp=mtr
TN79466
19
10-12-2016 04:53 PM
Unimog005
10-18-2006 04:26 PM
arsleuthster
09-09-2004 03:40 AM
