87 ford ranger 2.9 wont start - Ford Truck Enthusiasts Forums
Old 08-12-2014, 11:30 AM
Alm200 Alm200 is offline
Alm200 is starting off with a positive reputation.
Fuel pump runs continuously and when i pull the return line off the fuel pressure regulator gas just pours out it does have pressure at the rail fuel pump pressure tested good if you hit it with either it will hit so i know its getting fire and its getting fuel to the rail but it wont start just crank and crank and crank whats wrong???? Also fuel pressure regulator is new
Old 01-21-2015, 12:47 AM
moosey1981 moosey1981 is offline
moosey1981 is starting off with a positive reputation.
Check the coil and you probably have a bad head gasket.....
Old 01-21-2015, 08:02 AM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Having pressure doesn't mean its the right amount, if it hits with either, but won't run, it sounds like the new regulator is bad.
Old 01-23-2015, 06:20 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Welcome to FTE....I sent you an email.....
Quote:
1987 f150 5.0 Fuel injected 87fordguy 1987 - 1996 F150 & Larger F-Series Trucks 5 07-10-2016 02:39 PM
No fuel at rail. bobcf 1999 to 2016 Super Duty 9 08-17-2015 09:56 PM
terrible fuel problems please help mhobbs 1987 - 1996 F150 & Larger F-Series Trucks 5 06-21-2015 04:24 PM
FUEL PRESSURE POOR JOE SKI Bronco II 0 03-24-2015 05:46 PM
86 302 not holding fuel pressure Normspeed 1978 - 1996 Big Bronco 4 06-21-2013 07:23 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
