ford 1989 F350 7.5 flexplate - Ford Truck Enthusiasts Forums
Old 08-12-2014, 11:18 AM
lisagoud lisagoud is offline
lisagoud is starting off with a positive reputation.
what would be the most rugged crack resistant flexplate out there for extreme use ford 460 external balance to Ford c6
Old 08-13-2014, 12:36 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
Extreme use is pretty general. The stock flex plate can handle quite a bit of power. How built up is your C6? This is just as important as the amount of torque you will be putting to it.
Old 08-13-2014, 06:53 PM
motor is about 600 hp and mild build up on C6 for towing and 4x4 use ....mostly low end power. IU had heard good things asbout this one (any feedback out there?):
PRW 1846010 Xtreme Duty SFI-Rated External Balance 164 Teeth Steel Flexplate for Ford 429-460
05 B3000 v6 automatic Flex plate Spacer? mushman Ranger & B-Series 3 07-03-2016 08:22 AM
starter trouble gary's1950F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-27-2016 01:39 PM
78 351W AOD install problems Ab73ford 1973 - 1979 F-100 & Larger F-Series Trucks 18 07-10-2014 04:54 PM
390 flexplate metal spacer jeff14346 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-07-2011 11:44 AM
Ford Flywheel, flexplate and imbalance info TigerDan Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 03-19-2009 11:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
