Offroad & 4x4
Dana 44 seal leak question
Old 08-12-2014, 09:16 AM
dustyroad's Avatar
dustyroad
dustyroad is offline
My front diff axle seal(s) are leaking.
I have never been into a diff before so I thought I should ask before
I jump in.
In order to replace the axle seals, do I need to remove the gearing
to replace the seals? It looks like I don't, but it also looks like it might be easier if I did.
The repair looks simple enough besides ripping the front end apart for an 8 dollar part.
Any kits I should avoid or buy? Tips/tricks/pitfalls I should look out for?
Old 08-14-2014, 12:54 PM
dustyroad's Avatar
dustyroad
Let me ask this stupid question. If the front diff goes dry and I don't use/engage the 4wd will I burn anything up? My understanding of the 4wd is I won't.
I don't want to put the truck into the garage yet as I have other projects going on.
Yet I still need to drive it at times..
Old 08-14-2014, 12:59 PM
David7.3's Avatar
David7.3
David7.3 is offline
As long as your hubs unlock and your transfer case goes into 2 wheel drive, nothing in the front should spin, so you wont burn anything up
Old 08-14-2014, 01:54 PM
dustyroad's Avatar
dustyroad
Thanks David, I thought as much. Easier to ask now than learn later.
Old 08-14-2014, 05:35 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
as David said, you will be safe as long as everything is unlocked.
but for piece of mind, i would pull the plug and put a quart of gear oil in the diff anyway.
and to answer your question on replacing the seals, i always remove the carrier. it just makes things easier, and you get the added benefit of being able to thoroughly inspect everything while it is apart. .
reamer
03-23-2016 03:33 PM
F3fitty
10-06-2010 02:36 PM
Jared Putz
17
11-10-2003 03:19 PM
AKFord
04-14-2003 02:26 AM
Quick Reply: Dana 44 seal leak question
