Sct X4 flash tuner has white screen.
Old 08-12-2014, 08:31 AM
adammdennis11's Avatar
adammdennis11
adammdennis11 is offline
It will not load up correctly, when I plug it into the truck it flashes two white screens. If I take it in to the laptop, it does the a same thing. Has anyone ever experienced this?
I already emailed sct about this issue but have yet to hear from them.
Old 08-12-2014, 11:31 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
reset the unit. Mine has a very small hole where the SD card goes, use a paper clip to push the button inside the hole and see what happens. Call them... 407-774-2447
Old 08-12-2014, 12:21 PM
adammdennis11
I tried doing both, the little reset button does nothing...tried calling too...they must be a very busy company...I was on hold for over a hour before I decided to hang up...thanks for the help though.
Old 08-12-2014, 12:52 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
I stayed on hold yesterday for over an hour... just about to hang up and BAM.. it started ringing again and they answered. I will say, they walked me thru to the end.
Old 08-12-2014, 05:44 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
So tell us how the walk went.....
Old 08-13-2014, 03:14 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
When I was having a problem I used Email.
Very fast to answer and we got the problem
figured out. Turned out to be the USB port
on the desktop computer was not putting out
enough power to start the unit.
Plugged it into the laptop and bingo it worked.
Sean
Old 09-04-2014, 06:29 AM
adammdennis11
Sent the unit in to SCT, they replaced the lcd screen. Works great now.
Old 02-09-2017, 10:29 PM
Mario Serna's Avatar
Mario Serna
Mario Serna is offline
Help
Did u find an answer to ur problem iam having the same issue
Old 02-10-2017, 01:22 AM
brandonrr's Avatar
brandonrr
brandonrr is offline
If you read the (2 year old) post right above yours, you will see he had the screen replaced by SCT and it fixed the problem.
Old 09-29-2020, 11:44 AM
SgtNick_PSD's Avatar
SgtNick_PSD
SgtNick_PSD is offline
I had this problem when plugged into laptop, tried a different USB port on it (a USB3 port) and it booted right up.
hunter3014
Computer Chips & Tuners
02-18-2015 09:28 AM
qdrider01
10-28-2012 05:44 PM
Teds
08-04-2011 10:07 AM
F 250 6 liter
02-23-2011 01:03 PM
viperbluelx
01-08-2008 10:56 AM
Quick Reply: Sct X4 flash tuner has white screen.
