Dana 44 gear interchange
My 54 F100 has a Dana 44 rear axle. Although I already have a 9" to swap in, I am curious to know if it is possible to swap in a modern carrier with lower gears to change the ratio of the old Dana 44 from 3.98 to something like 3.25 or 3.00?
I suspect that a Dana 44 has less drag than a 9".
Thanks in advance.
Thanks in advance.
Hey Paul! Sorry no one has gotten to you. I'm sure you've already made the swap to the 9". Both are approx. the same size and the drag is pretty much even between them.
And yes, you can do any up-grades you wish with modern components. They are all the same. You may have the 28 spline axles, and may want to stick with them. The stronger 31 spline axles are useful fro big horse power rigs. You may be able to get away with a 20.1 with an auto tranny. A 3:50.1 with a standard tranny is great in the city traffic.
Talk with you later. Can you post some pictures of your rig?
TomThrall
02-26-2004 06:28 PM
big_red_79
05-30-2003 12:37 PM
