Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Water pump replacement on a '92 460 - a few questions
  #46
Old 08-21-2014, 08:49 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
Like these.
TCI Auto/Cooler quick-mount kit for coolers and electric fans includes nylon mounting rods, rubber shock pads and locking nuts (821500) | Cooler Installation Kit | AutoZone.com
Click the image to open in full size.
__________________
"Failure is the opportunity to begin again more intelligently." Henry Ford
1989 F250 460 C6 D60 front 10 1/4 rear 3.55
1990 F150 300 4R70W, 2004 Silverado 5.3
1982 IH S2500 400 Cummins 13spd
1994 CAT 953B 3116 Hydrostat
  #47
Old 08-21-2014, 08:54 PM
eakermeld's Avatar
__________________
  #48
Old 08-22-2014, 12:27 AM
SoCalAngler's Avatar
SoCalAngler SoCalAngler is offline
SoCalAngler is starting off with a positive reputation.
great! If you ever get a chance, a pic of your cooler to show how it is mounted would be appreciated
thanks
__________________
'92 Ford F-350 XLT, 4X2, Crew Cab, Long Bed, 460ci, E40D, SRW, 3.55
  #49
Old 08-22-2014, 01:57 AM
Pappawheely's Avatar
Pappawheely Pappawheely is offline
Pappawheely is gaining momentum as a positive member of FTE.Pappawheely is gaining momentum as a positive member of FTE.
I removed the heat exchanger on my 460. The thought of my oil circulating through a water passage was not a good one. I made a manifold that replaces the exchanger (painted blue)
I put an adapter on the oil filter mount for a remote filter. I then fabbed a mount for an oil cooler and a trans cooler that mounts to the X-member of my shackle reversal mount.
__________________
1992 FORD F-350 Crew 4X4. 460 gas, Manual 5-speed. Sky's Offroad Design shackle reversal, Atlas Spring progressive spring packs, Falken 37x12.5-17 Wildpeak AT's. Trailready 17x8.5 beadlocks with World Series rings. Warn Winches M10000 and ZEON 8. Odyssey Batteries, Power Master 200 amp alternator. Centramatic Dynamic Wheel Balancers. Pressure Pro TPMS.
Similar Threads
Question about front cover plate. coolant leaking from it. ollirrap 1973 - 1979 F-100 & Larger F-Series Trucks 25 01-01-2015 08:31 PM
Water pump replacement on a '92 460 - a few questions SoCalAngler Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-10-2014 05:23 PM
1979 f-250 loosing water fast projectdagger 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-04-2013 11:50 PM
91 F150 dumping coolant jf52 1987 - 1996 F150 & Larger F-Series Trucks 8 07-15-2007 09:08 PM
Timing chain replacement sealants, RTV or Permatex Tack & Sealant b4hntn 1978 - 1996 Big Bronco 6 07-02-2006 05:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
