I don't know what year you have, but I believe I used a 3/8" bolt for the top rear of the front fender to the cowl, while the lower mount was a 5/16" stud on the frame. The top of the fender bolts to the inner fender with 5/16" bolts, as well as the grill and upper pan bolts.
what size bolts should be used to attach the front fenders to the cowls ????
You've gotta use the 5/16 UNF bolts on the cage nuts on the cowl. Same with any of the threaded nuts on the radiator support, J nuts on the grill etc. If you need nuts and bolts I.E. Inner fenders to fenders you can use 5/16 UNC. I just use UNF for all of them so I'm not tempted to use the wrong bolt in the wrong place.
I forgot about the threads in the radiator supports. Thanks for pointing that out.
