front fender to cowl - Ford Truck Enthusiasts Forums
Old 08-11-2014, 08:15 PM
zombiefied 247 zombiefied 247 is offline
zombiefied 247 is starting off with a positive reputation.
what size bolts should be used to attach the front fenders to the cowls ????
Old 08-11-2014, 09:40 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
I don't know what year you have, but I believe I used a 3/8" bolt for the top rear of the front fender to the cowl, while the lower mount was a 5/16" stud on the frame. The top of the fender bolts to the inner fender with 5/16" bolts, as well as the grill and upper pan bolts.
Old 08-11-2014, 09:59 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Zombiefied, if this is your '55, they are 5/16" x 3/4". From the factory they were fine thread (24), but the coarse thread (18) is good too.
Old 08-12-2014, 09:06 PM
I keep forgetting to put my truck year in my post sorry about that. thanks for the info guys
Old 08-12-2014, 09:11 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Quote:
You could put the year and model in your sognature and it would be there in all your posts.
Old 08-12-2014, 09:27 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
You've gotta use the 5/16 UNF bolts on the cage nuts on the cowl. Same with any of the threaded nuts on the radiator support, J nuts on the grill etc. If you need nuts and bolts I.E. Inner fenders to fenders you can use 5/16 UNC. I just use UNF for all of them so I'm not tempted to use the wrong bolt in the wrong place.
Old 08-12-2014, 09:30 PM
Quote:
I forgot about the threads in the radiator supports. Thanks for pointing that out.
Inner fender webbing? oscajo 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-07-2015 08:49 AM
1953 hood and front fenders patio1953 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-28-2015 07:04 AM
Front fender seals olguy317 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 09-28-2014 02:26 AM
Cab Corner Cowl replacement Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-03-2014 02:09 PM
Sagging front fender tip49 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-26-2014 11:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
