Air Ride Suspension - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Air Ride Suspension
Old 08-11-2014, 07:46 PM
dieselsubmariner's Avatar
dieselsubmariner dieselsubmariner is offline
dieselsubmariner is starting off with a positive reputation.
Air Ride Suspension
I'm sure this has been discussed here before, but I'm playing with the idea of changing the rear suspension of my truck to air ride. I thought at first of adding the overload bags, but they will only provide me with additional load capacity, but not a smoother ride.
I know, complete systems are available, but they are way to pricey.
I read somewhere, that some guys used parts from semi-trucks and build their own system. Any idea / link of a good solid diy system?
Old 08-11-2014, 10:30 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
This should provide some food for thought.
http://www.ford-trucks.com/forums/10...tml?styleid=20
Old 08-13-2014, 01:33 PM
Thanks for that info. I am still trying to decide what route to take . Maybe to keep cost down , I just add the overload air bags . At the moment I do know , that my truck sits lower than most other f350 even though I did not lower it . But than again the rear end is very hard, sags some with a trailer behind it . I was hoping in changing to total air ride to maintain always same riding height but also be comfortable .... Any thoughts ?
Old 08-13-2014, 05:11 PM
Gicknordon's Avatar
Gicknordon Gicknordon is online now
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
You could go to softer rear springs for ride quality and the helper bags for pay load capacity.
Old 08-13-2014, 07:41 PM
Would you reccomned to remove one leaf or get a different spring? If so, where from?
Old 08-15-2014, 02:51 AM
21411 21411 is offline
21411 is starting off with a positive reputation.
i thought you dropped the springs and removed many leafs. since they would only be used for keeping the rear end in place, not supporting weight anymore.
Old 08-15-2014, 08:42 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I replaced my front coil springs and gained 3" of height, if that helps you. I have bags on the rear and really like them.
Old 08-15-2014, 08:48 AM
Well if I gain 3" on my front axle, I drive uphill . My truck currently is level. But I do believe my front springs are wore . Are there any airbags available that would fit inside the front coil ? If I replace , any good source ?
As for my rear axle , I can jump on my back bumper and she only moves about 2" max but maintains to be very hard suspension
Old 08-15-2014, 11:06 AM
Thor'sHammer's Avatar
Thor'sHammer Thor'sHammer is offline
Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.
Here's what I have on the front and rear.
Front
Rear
Old 08-15-2014, 06:06 PM
Well, my truck is 2wd , therefore your front set up won't work. In regards to your rear axle, is this a kit or did you build it ? Any more info?
Old 08-15-2014, 09:34 PM
It is a kit from www.airslamit.com. the kit came with everything and was $225.
Old 08-15-2014, 11:14 PM
My neighbor has air bags inside of his coils so I guess you can find them.
Old 08-16-2014, 08:43 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Air lift brand has bags for inside. They will make it ride terrible in front.
Air in rear and remove leafed sucks too. I have some experience with a major manufacturer that has a system like that.it sucks.you won't like it.and especially on theses trucks with axle wrap a problem.remove springs and it will be even worse.
The only correct way in my head is a four link and bags completely supporting the rear.great ride and adjustability would be had. Otherwise you are wasting your money.kelderman or ride tech should be of assistance.ride tech I believe used to do a kit for a 2wd SD just not sure on obs how much different.2wd I believe could be fairly close.
There isn't much better than a SD that lays it out!!!!!
Old 08-17-2014, 07:31 AM
I can assure you that the ride is stiffer as you claim, if you leave air pressure in the bags with the truck unloaded. I have a travel trailer that has a tongue weight of over 1400lbs. I can level the truck with 55 psi in the rear bags and 20 psi in the front and maintain the ride quality as if the truck didn't have airbags.
Axle wrap? Your springs must be shot. I've never encountered axle wrap.
Old 08-23-2014, 09:40 AM
I think i might be scoping out the local salvage yards. I know that some ambulances have the air ride in the back as well as some busses. just not sure about the front. I might just change the springs itself and see if that helps.
2003+ Ford Expedition & Lincoln Navigator Air Ride Suspension Down Tips makuloco2000 Expedition & Navigator 3 02-09-2016 01:34 PM
Smart Phone Accessible Air Suspension Help & Store American Air-1 Expedition & Navigator 0 02-04-2016 12:53 PM
Air Bag Suspension Offer Better Ride??? turbinefix 6.4L Power Stroke Diesel 0 01-20-2016 03:53 PM
Air ride suspension quesey 1994.5 - 1997 7.3L Power Stroke Diesel 7 05-27-2014 09:45 PM
Best F250 shocks #LHB# 1999 to 2016 Super Duty 19 09-12-2013 07:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
