vacuum line questions? - Ford Truck Enthusiasts Forums
Old 08-11-2014, 04:48 PM
kjadams1971 kjadams1971 is offline
kjadams1971 is starting off with a positive reputation.
Hello I'm new to this forum. I have a 1988 ford f250 4x4 with the 460 or 7.5l engine. I just installed a used engine and it took me about to months to finis it and get it running. with that being said I must have for got where some vacuum lines go and come from. so here is my ? my heater control worked perfectly before I started and now it will not switch from defrost to vent to floor. I know I have got a vacuum problem some where. So if anyone can tell me where I can get vacuum diagrams I would really appreciate it.
Old 08-11-2014, 05:31 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
The best answer is the correct year Electrical & Vacuum Troubleshooting Manual for F150-250-350 and Bronco.
(this is a Ford manual usually available from Helm Inc. or used on Ebay)
My carbureted '87 460 does not have a vacuum reservoir for climate control, but if your EFI version does have a plastic ball or coffee can on the passenger fender then you know where to start looking.
On my truck that vacuum line comes from a plastic tee on the firewall (above the passenger side valve cover) to an inline check valve and goes into the cab just below the heater hose connection on the firewall.
These hard plastic lines get very brittle.
The easiest way to repair them is to purchase bulk rubber line that slips over tightly.
Sorry, I do not have the correct EVTM for your EFI truck.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 12:59 PM
Ported Vacuum Switch for Vacuum Advance? Ford59galaxie 1973 - 1979 F-100 & Larger F-Series Trucks 21 02-12-2016 05:29 PM
Vacuum line replacement on a 1987 4.9L straight six 87oldtimer 1987 - 1996 F150 & Larger F-Series Trucks 8 06-03-2014 06:02 PM
vacuum line into cab for heat. tjc transport 1999 to 2016 Super Duty 5 10-23-2013 12:14 PM
Vacuum advance question alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 14 06-27-2013 04:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
