need help ,looking to buy an 03 explorer - Ford Truck Enthusiasts Forums
Old 08-11-2014, 03:44 PM
5speed50 5speed50 is offline
5speed50 is starting off with a positive reputation.
Can I get some pointers on what to look for ,when buying an 03 explorer 4x4 with the 4.6 v-8?
What problemes do they have?
thanks!!
Old 08-11-2014, 03:50 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Make sure you have proper air flow out of the A/C ducts..
Blend door(s) tend to go bad and there are a number of cheap 'solutions' but you might be able to claim the $900 dealer repair price to get the price down.
I had the air inlet door (controls recirculate or fresh air) fall down and essentially block all air flow on my '04 Explorer. Others have bend door (controls blending of hot/cold air) to maintain the set temp, since it's almost constantly adjusting you can imagine why/how it fails..
Old 08-11-2014, 04:22 PM
Thats good thanks!!! any timming chain trouble with the 4.6?
Old 08-11-2014, 05:52 PM
shorod's Avatar
shorod shorod is online now
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
The 4.6L V8 is pretty trouble-free, no timing chain issues. The 5-speed automatic transmission though is less trouble-free so pay attention during the test drive for any strange shifts or harsh engagement in to reverse.
Rear wheel bearings are another fairly common wear point that you might which to have inspected.
Also check for a door ajar indication and make sure the interior lights work as expected (versus someone just pulling a fuse for the interior lights). Worn door switches are pretty common to cause the door ajar indication. Additionally, make sure all the power windows, door locks, and driver's door speaker work from the driver's door, both open and closed. Broken wires between the driver's door and cabin are somewhat common and could act up with the door in either the open or the closed positions.
-Rod
Old 08-11-2014, 06:57 PM
-Rod
This is good THANKS , anyone else have anything?
Old 08-11-2014, 09:43 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
see if the rear axle and transmission have had oil changes. How may miles ?
Old 08-12-2014, 04:52 AM
Quote:
its a 125th mile truck ,He said he had all the fluids changed when he got it ,6 mounths ago
Thanks for the help!
looking to buy a 2007-2010 explorer,what motor and trani do I want 5speed50 Explorer, Sport Trac, Mountaineer & Aviator 2 01-16-2016 04:05 PM
Explorer Pricing street rodder 2011 & Newer Explorer 9 01-14-2015 02:37 PM
1995 Explorer Transmission Options ekkavan Clutch, Transmission, Differential, Axle & Transfer Case 2 08-15-2014 04:59 PM
What to expect from 2003 4.0L flex fuel Explorer? Frat-man-du Explorer, Sport Trac, Mountaineer & Aviator 4 12-26-2012 08:37 PM
Looking at a Sport Trac ncranchero Explorer, Sport Trac, Mountaineer & Aviator 8 12-17-2008 09:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
