Need help with P1400 code (2000 Explorer) - Ford Truck Enthusiasts Forums
Old 08-11-2014, 03:11 PM
ImNotABotOMG ImNotABotOMG is offline
ImNotABotOMG is starting off with a positive reputation.
Hey, guys and girls! Let me start off by apologizing if this is in the wrong forum, I'm new here!
I have a 2000 Eddie Bauer Edition Ford Explorer (with the 5.0) and I've been having some trouble getting it to start. I mean it starts, but it takes it a couple minutes to get started.
We pulled a P1400 code off the truck and researched it. Everybody said it was probably the DPFE sensor so we took a couple hours to replace that (me and my dad- holy crap that thing was hard to get to). But the check engine light didn't go off and is still does the same thing. Help me? Thanks!
Old 08-11-2014, 05:57 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Are you sure you replaced the DPFE versus the EGR valve? The DPFE typically is not too hard to replace and entails one electrical connection and two vacuum hoses. I will caveat my comment that I have not specifically changed the DPFE on a 2000 Explorer V8, but on the others that I've looked at, the DPFE was not bad to get to.
-Rod
Old 08-11-2014, 06:45 PM
Yeah, it was the dpfe sensor. Two hoses and an electrical collection. It was just hard to get to because the dipstick for the transmission fluid was in the way and we couldn't get our wrench and socket down in there.
It might also be worth noting that I'm getting terrible gas mileage. About 9.6 mpg to be exact. Do you think it could be the egr valve? Thanks for the help, man!
Old 08-11-2014, 11:26 PM
shorod's Avatar
From the factory service manual, here are the possible causes of this P1400 code for your 2000 Explorer:
  • DPFEGR circuit short to GND
  • Damaged DPF EGR sensor
  • VREF short to GND
  • Damaged PCM
The manual continues to provide this diagnostic help:
A DPF EGR PID reading less than 0.2 volt with the key ON and engine OFF or running, indicates a hard fault.
Do you have access to a scan tool that will allow you to monitor the DPFE value real time?
-Rod
Old 08-12-2014, 12:14 AM
Yes, I do. What do I scan? Just the DPFE Sensor?
Old 08-12-2014, 07:44 AM
shorod's Avatar
You'll want to scan for something related to the EGR voltage. It's hard to say what the implementers of your scan tool decided to call it. It might be DPFE Voltage, it might be EGR Position, or it might be EGR Voltage, etc.
-Rod
Grinding Sound Plus P1774 Code...HELP Pibryan 1999 to 2016 Super Duty 0 01-07-2017 04:22 PM
Help with trouble codes RJL1 1987 - 1996 F150 & Larger F-Series Trucks 4 12-11-2016 10:49 AM
New guy same old problem. HELP PLEASE LetsGetIT 2004 - 2008 F150 4 07-10-2015 11:23 PM
Occasional reoccurring problem. Wont go above approximately 1400 rpms. austinberry7.3 1999 - 2003 7.3L Power Stroke Diesel 2 03-20-2015 11:09 AM
this damn 7.3 Bandito1 1999 to 2016 Super Duty 8 10-07-2014 01:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
