Front spring replacement - Ford Truck Enthusiasts Forums
Old 08-11-2014, 02:06 PM
JPMallory's Avatar
JPMallory JPMallory is offline
JPMallory has a very good reputation on FTE.JPMallory has a very good reputation on FTE.JPMallory has a very good reputation on FTE.
I'm planning on replacing my front springs and shocks very soon. I've never done this before. Is there anything I should look out for/be aware of before I do this?
Old 08-12-2014, 08:48 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Not sure where you're planning on getting your Springs but hopefully they will come with the bushings installed. You'll need new shackle bolts. Make sure they fit the bushings before trying to install the springs. Sometimes you may have to have the bushings reamed to fit the bolts. Also check the hanger bars for wear. 1953-56 Ford F-100 Spring Hanger Bar, Front Outie Notch, Replacement
You'll also want to pick up new U Bolts, nuts and a few straight axle alignment shims. Don't forget to get the ole Iffy realigned after you complete the Job.
Shocks are pretty straight forward UNLESS you're using dropped springs. If your dropping the front end you'll need to get shocks that match the drop or reposition the shock mounts to compensate for the drop.
Old 08-12-2014, 09:01 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Not knowing what your experience is, be sure to use jack stands under the frame. Make certain the jack stands are on a solid surface. If the truck were to fall, it could make for a bad day.
Old 08-13-2014, 12:33 AM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
Well here you have my work documented so far
itīs both on rear and front suspension, bushing replacement, reaming etc
DinnerHill SpeedShop: Front axle
DinnerHill SpeedShop: Front suspension
DinnerHill SpeedShop: Leaf springs
DinnerHill SpeedShop: Rear suspension
Let me know if you have any questions
Old 08-13-2014, 06:47 AM
Lookin Good!
Old 08-13-2014, 09:03 AM
JPMallory's Avatar
Thanks. I bought the springs from macs, and they should be here today. Unfortunately the bushings and pins are on backorder.
I'm going stock ride height, so I should be fine on the shocks.
Front springs green_95 1994.5 - 1997 7.3L Power Stroke Diesel 4 05-18-2016 05:01 AM
Front Springs '72 F250 1972RubberDuck 1967 - 1972 F-100 & Larger F-Series Trucks 1 05-11-2016 02:25 AM
Leaf Spring Install Help - 77 F250 Joel Cassell 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-03-2016 08:12 PM
Aerostar Front spring replacement eds94aero Aerostar 13 06-09-2011 10:19 AM
New Front leaf spring questions Monster-4 1999 to 2016 Super Duty 10 02-05-2011 04:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
