what carb are you guys running on 390? - Page 2 - Ford Truck Enthusiasts Forums
Old 08-21-2014, 08:08 PM
DarkWolf40's Avatar
DarkWolf40 DarkWolf40 is offline
DarkWolf40 is starting off with a positive reputation.
I've got a 410 and I'm running a EB 1825 on it, I think its a 650cfm. runs good but very hard to start cold.
Old 08-27-2014, 05:22 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Quote:
Originally Posted by Krewat View Post
Large port manifold to small port head might cause gas to drop out of the mixture as it hits the "wall" surrounding the small port. Causing all sorts of weird issues that'll have you thinking the carb needs more tuning.
I could be wrong of course
It wasn't as bad a deal as some make it out to be, Ford did this on a couple of factory combos, on the 429's Seen this on a factory jet boat engine too with an SCJ intake on an otherwise stock 460.
Old 08-27-2014, 05:39 PM
mfnheff mfnheff is offline
mfnheff is starting off with a positive reputation.
So far the intake/head combo is running like a champ. Pulls hard through all gears at the revs I've been running so far. Idle is smooth. Vacuum is steady.
When I put it together I reminded myself my aim was a low rpm engine to run in a truck that weighs 4900lbs. I figured the port mismatch would likely cause problems at higher rpms, if any problems were to arise. And I doubt I'll spin this thing 5 grand.
If it ever becomes and issue I'll sell that intake, cause I guess it could be kind of rare, and buy a performer rpm or similar.
Head Machine Work? BigBlocker0248 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-17-2016 03:20 PM
Refresh of a rebuilt 400 buckin69bronco 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 13 06-23-2015 01:37 PM
CR, deck clearance, which piston? mckoloum 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-06-2014 11:13 AM
best cam for 390 FE???? 1976f150dude 1973 - 1979 F-100 & Larger F-Series Trucks 20 11-19-2014 05:03 AM
Thoughts about how to build my motor and other questions.(keywork Tractor like torque) 59flatbedford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 02-14-2012 08:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
