Y block adapted to newer upgrade trans
Here is one to connect a C4 to a Y-block. I have one on my 56 Fairlane, works very well.
The Y-Block
The Y-Block
Y block transmission swap
Thanks for all the information. How satisfied were you with the C4 in the 1956 Fairlane compared to before? I would like to keep my 312 Y block in my build, but I want more efficiency on the road with a later automatic trans. I have a good C6 transmission that I could use and I have access to several of the C4 transmissions. psmith1951
I've got a truck Flat-O but haven't got it put in yet. I also bought a car Flat-O bell housing and flex plate at a swap meet. I got the rest of the stuff from Gene at Flat-O to make it work but in order to install it in a truck you'd have to change to car motor mounts and add a transmission crossmember for the C4.
Trying to get the ole Y Block purring before I change it over to an automatic. Added a Ford ECZ 9425-B single 4 barrel intake, a Holley 390 CFM 4 Barrel, a Pertronix Ignitor III & Flame Thrower III coil. Still gotta work on the tune and add headers.
jmadsen
09-13-2008 12:24 AM
55rodder
13
12-11-2003 07:07 PM
hpguy
02-04-2002 11:29 AM
darkknight
05-05-2001 12:17 PM
