Oil Sender Question...
Well this is likely a simple, dumb couple of questions, but here goes. First, what is the thread size for the oil sender in a 351W block? Does the oil need to be drained to remove the sender?
I ordered a set of gauges and a pillar pod for them. The oil sender that comes with the oil pressure gauge uses 1/8" npt threads. I want to know if I need to order an adapter or not. I read through a write up on how to install the gauges over at NLOC and they said it used the 1/8" npt thread, but other site I look at say 1/4" npt.
linckeil
11-28-2010 05:22 AM
Mike F250
02-18-2009 10:22 AM
86ford
11-13-2004 05:19 PM
