1950 F1 truck (o) - Ford Truck Enthusiasts Forums
1950 F1 truck (o)
Old 08-10-2014, 07:16 PM
easyrider47 easyrider47 is offline
easyrider47 is starting off with a positive reputation.
1950 F1 truck (o)
need some help with repairing floor.......previous owner did not cut out any of the rusted floor and did a poor job of patching over..........
..thanks for you help
Old 08-10-2014, 08:25 PM
FortyNiner's Avatar
FortyNiner FortyNiner is online now
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Pics would be a help. Replacement floor panels are one option.
Old 08-10-2014, 08:33 PM
Oh5dually Oh5dually is offline
Oh5dually is starting off with a positive reputation.
Pics would be great!
It also depends on how you would like to do so. There are a couple of different methods! Anywhere from cutting, welding, grinding to rust encapsulators.
Old 08-13-2014, 06:59 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
It really depends upon the extent of the rust. Mine started out looking to be a simple patch job but it quickly became apparent that I needed to do it right and weld in new panels. Make sure that you remove some panels and the front fenders to decide which of these replacement panels you need.
Dennis Carpenter sells the full floor panel for $600 - a bit pricey and the back of my floor was in good condition. I got mine for $75 per side (front only) from Northern Classic Truck here in Michigan. They are only just across town so I saved the shipping too.
Left side after floor removal
Right side at A pillar had the worst rust
Right side . . . you will need to trim the panels to fit your need.
And you may need to make some odd pieces to fit where the patch panel does not cover. Home Depot sells 1' or 2 ' sheet steel in 16 gauge. You may have to search through their stock as they usually only have the thinner 22 gauge in plentiful stock.
Dennis Carpenter full floor - $600 !
This is what I bought for $75 from Northern Classic Truck
If your floor is gone along with the bottom of the A pillars you can buy this assembly from NCT but it is $470. In hindsight I might have been better off getting a pair of these. Check your truck carefully to see how far the rust has gone.
A couple other tips:
  1. AXRacer has done some great posts here on FTE on mig welding. You might want do a search on his name to find them.
  2. EASB Easy-grind welding wire makes the finishing much easier.
  3. Eastwood weld-through primer is good to use on the surfaces that will be blind after the job is complete.
Interior - Carpet or Rubber? treverd 1967 - 1972 F-100 & Larger F-Series Trucks 6 11-17-2015 02:07 PM
Flooring over MC access cover... Tilleyman 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 11-16-2015 07:50 PM
Floor Mats djm1204 1999 to 2016 Super Duty 3 01-20-2015 01:12 PM
FLOOR SHIFTER FOR AOD TJ62 1967 - 1972 F-100 & Larger F-Series Trucks 5 11-30-2014 12:23 AM
1959 F1 Pickup ( O ) easyrider47 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-11-2014 01:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
