Water pump replacement on a '92 460 - a few questions - Ford Truck Enthusiasts Forums
Old 08-10-2014, 06:23 PM
SoCalAngler's Avatar
SoCalAngler SoCalAngler is offline
SoCalAngler is starting off with a positive reputation.
Changing out the water pump on my 1992 460.
Questions:
1. Is it recommended to also remove the aluminum cover behind the water pump and replace its gasket?
2. What all is involved in replacing the cover gasket? I know there is a paper/fiber gasket similar to water pump gasket, but are there other gaskets behind cover that will also need to be replaced? Is this opening a can of worms?
Currently, these parts are not leaking. I am replacing water pump, as I am replacing the radiator and figure it wouldn't hurt to have a new water pump in there.
Thanks
Question about front cover plate. coolant leaking from it. ollirrap 1973 - 1979 F-100 & Larger F-Series Trucks 25 01-01-2015 09:31 PM
Leaking water pump replace gasket only? kbarbee95 1999 - 2003 7.3L Power Stroke Diesel 9 11-28-2014 04:38 PM
Water pump replacement on a '92 460 - a few questions SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 48 08-22-2014 02:57 AM
Water Pump / AC Comp bracket questions - 1992 460 SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 9 08-12-2014 07:40 AM
Straight up timing set and smog TexinCali Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 03-19-2014 11:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
