1999 F250 Super Duty 2wd Front lift kit
Hey guys, want to raise the front of my 99 f250 super duty. I only found rough country for my options but im open to suggestions. Im looking for a 2-3" lift. Will the 3" lift spindles work fine? What else am i going to need? Shocks? Any info is appreciated. Thanks
http://www.roughcountry.com/suspension-lift-kits/ford-suspension-lift-kits.html?vehicle_drive=4&vehicle_year=76
Spindle lifts do not require shock changes. The lift is achieved by moving the spindle shaft down on the steering knuckle from its original position.
if you do a coil spring lift then longer shocks or shock drop brackets will be required depending on how much lift. In some small 1-2 inch lifts the stock shocks are long enough to work. Obviously depend on the application
Micheal Murphy
2017+ Super Duty
08-12-2019 02:22 PM
10Superduty
1999 to 2016 Super Duty
03-11-2014 05:11 PM
