07 6.0 f250 runs but no boost and won't drive.
Old 08-10-2014, 02:55 PM
Whitetailhntr's Avatar
Whitetailhntr
Whitetailhntr is offline
Was travelling to a job site today. Driving up a steep hill and when the truck downshifted it started pouring black smoke. By the time I got pulled over at the top of the hill the truck had overheated and was dumping coolant. Anyhow got it cooled down and topped up coolant and will start but has no boost and dies as soon as I try and rev it up. Had it towed to diesel shop. Any idea what it my be? I've dumped over 8k into this truck in the last 10 months. Injectors, FICM, bent pushrods and a new hpop. Not sure if I can afford to keep this piece of crap. Maintenance is done as required and use synthetic oil and oem filters. Truck has 140k miles on it and I've owned since new and is still bone stock, no deletes, chips or tuners.
Old 08-10-2014, 03:04 PM
Edogsf350's Avatar
Edogsf350
Edogsf350 is offline
how did you bend push rods? I have never read on here about someone bending push rods
Old 08-10-2014, 03:07 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
whats the smoke smell like Diesel fuel??
I can tell by the parts list your mechanic is probably taking advantage of you
you may have a Bad Injector a Bubble test is Needed and if the truck eats injectors then you might have low fuel press
Old 08-10-2014, 03:08 PM
Whitetailhntr
No idea really, shop said the first was due to so exhaust issue and the second one was due to an intake issue... I'm no mechanic so it's all Greek to me.
Old 08-10-2014, 03:12 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
is all that work recent???
more info would help
Your HPOP PER your Model Year has been a GREAT ONE Few Failures so this is why I suspect the mechanic is either ripping you off or a *******
Old 08-10-2014, 03:15 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
you need a New Shop
this Pisses me Off there Liars
you could have rebuilt the engine for 8K
Old 08-10-2014, 03:17 PM
Whitetailhntr
Not sure about the smell of the smoke. I was driving and just trying to get pulled over of a busy highway. It was black and lots of it.
The injectors and FICM were done by a different mechanic. We have since moved to a different town since then and the shop I used here came highly recommended and seem to be straight up. The owner of the shop is a stand up guy and has a good reputation.
Old 08-10-2014, 03:18 PM
Whitetailhntr
you need a New Shop
I live in northern Alberta in Canada. A new engine here will run 12-13k.
Old 08-10-2014, 03:21 PM
Whitetailhntr
He said it was only the 3rd hpop he's ever done on an 07. The first pushrod was in April, hpop was in May and the second pushrod was about 3 weeks ago. The other stuff was last august done by different mechanic
Old 08-10-2014, 03:26 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I hope the new shop is better
IDK how many times ive seen shops replace all 8 inject plus the FICM all in the same shot (This problem is common and normally a 400$$ FICM Repair)
They cant diagnose a Faulty injector with a Bad FICM (Fuel Injector Control Module ) you must fix the FICM First and Retest cylinder balance
But they do it all the time
Old 08-10-2014, 03:42 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Push rods don't normaly just bend on there own
They bend when they Runaway or if the heads had been off and not installed correct or a Injector that Blows its tip off into the cylinder
have all the bent push rods been on the same cylinder??
Old 08-10-2014, 03:46 PM
Whitetailhntr
The FICM was replaced first and then tested. Injectors 4 And 6 were showing as bad and then replaced. Truck ran very well till April then just sarted having problem after problem... It's very frustrating and costly. I use my truck for work everyday and when I'm without it I pay for repairs plus have to rent vehicles and then use my wife's Tundra for work. It all adds up in a hurry. As good as the tundra is it's not a 3/4 diesel that I need day in and day out.
Old 08-10-2014, 03:52 PM
Whitetailhntr
Yes they were both on cylinder 2. If have to look at the invoice but seems I remember something about a broken rocker the first time around.
Old 08-10-2014, 04:04 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Canada well I hear everythings expensive there
Do you guys know if Mike is by this guys location?????????
Edit looks like mike is in Ontario
Old 08-10-2014, 04:14 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
does your truck have a stock boost gauge then
maybe it blew a CAC Boot off
you could check them easy enough theres 4 of them start at turbo and follow the tubes
Quick Reply: 07 6.0 f250 runs but no boost and won't drive.
