I put a new glow plug controller in!!
Old 08-25-2014, 07:01 PM
DmanNC's Avatar
DmanNC
DmanNC is offline
I installed a new glow plug controller today. I wasn't sure I really needed one or if it was the glow plugs, until I removed it. Yep I think its bad, here is a pic of it.
Old 08-25-2014, 07:51 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Wow, yep, that qualifies as bad.
Old 08-26-2014, 06:57 AM
DmanNC's Avatar
DmanNC
DmanNC is offline
Success! So far anyway. It 57 here this morning and the ole girl fired up almost instantly. That's a first.
Old 08-26-2014, 07:02 AM
David7.3's Avatar
David7.3
David7.3 is offline
you should ohm out your glow plugs just to be on the safe side, it's easy with a OHM meter, unplug glowplug touch one lead to ground the other to the glowplug terminal and you should get about 4 ohms, cold. That way you know your ready for winter and you wont melt anything else.
Old 08-26-2014, 07:06 AM
DmanNC's Avatar
DmanNC
DmanNC is offline
I will do that, thanks. I was thinking about just changing them out anyway. Not knowing what brand of plugs are installed is making me nervous.
Old 08-26-2014, 07:30 AM
David7.3's Avatar
David7.3
David7.3 is offline
If they ohm out ok, put the money into something else, If you do replace use motorcraft and put neverseize on the threads.
Old 08-27-2014, 03:34 PM
DmanNC's Avatar
DmanNC
DmanNC is offline
Ok I have ohm checked the glow plugs, 1 is reading 6, 1 @ 7, 3 @ 4 and 3 @ 3. So what exactly does this mean???
jjs1988
10-06-2009 11:52 AM
countrysF250
17
11-02-2007 08:32 AM
turboman24
04-07-2007 11:47 AM
Gr8ride
09-05-2005 11:13 PM
shagginwagonvic
01-07-2003 11:39 AM
Quick Reply: I put a new glow plug controller in!!
