Ground wire & picture attached
08-10-2014, 12:41 PM
on
Found this ground wire hanging. Does it attach to anything?
08-10-2014, 12:52 PM
That ground is supposed to run to the intake plenum I believe.
08-10-2014, 02:18 PM
Yeap as EvanP said. I think the #5 or #6 intake runner is where it attatches to the plenum.
08-10-2014, 02:27 PM
on
Thank you
Thanks for the replies. Where is the intake plenum located? This being disconnected, what effect would it have?
08-10-2014, 06:31 PM
My 87-91 trucks have a ground wire on that bolt just above the heater hoses. If yours is an 87-91 you are missing the ground wire on the firewall right above the heater hoses where they go through the firewall into the heater core.
08-10-2014, 07:10 PM
on
Thank you for the good reply. I have a 1993 f150 4.9 L 6 cylinder. The fact it's not connected, will it cause any issues?
08-10-2014, 08:00 PM
on
Better to have it connected and not find out...
08-11-2014, 05:18 AM
that is the body to engine ground wire.
connect it to any clean metal part of the engine and you will be good to go.
jerkypants
05-28-2014 07:20 PM
Marc150
02-03-2004 07:48 PM
heavypea
10-29-2003 07:42 PM
Irysh
1978 - 1996 Big Bronco
05-08-2003 10:36 AM
prodigy
01-15-2003 09:47 PM
