torsion bars vs. coil springs? - Ford Truck Enthusiasts Forums
Old 07-11-2003, 10:23 PM
WXboy's Avatar
WXboy WXboy is offline
WXboy is starting off with a positive reputation.
Some new trucks have torsion bar IFS, some have coil springs IFS. I noticed that Ford is ditching the torsion bars for the '04 F-150. That says to me that torsion bars might not be the best. What are the advantages/disadvantages of each setup?
Old 07-12-2003, 04:28 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
From working at a Ford dealer until 2000, I can say I saw a lot of Ford trucks, of different models, come in with broken torsion bars when they really should have not broken. They usualy break off near the rear bracket. I do not think I ever saw one come in with a broken leaf spring or coil, front or rear.
Good thing about torsion bars, once broken they make great pry bars.
Old 07-13-2003, 01:05 AM
proeliator proeliator is offline
proeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to behold
Plymouth Dusters used torsion bars. 'Nuff said
Old 07-13-2003, 02:35 AM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
Do a search for broken spring here and you'll find plenty of people complaining about the rear leaf springs breaking on their trucks.
Old 07-13-2003, 05:50 AM
13hondacr250's Avatar
13hondacr250 13hondacr250 is offline
13hondacr250 is starting off with a positive reputation.
WXboy. I see your little pic under your name says 4x4 offroad. You going to use this truck off highway? Coils are great, ride good and can be assisted with air bags quite easily is the shock is not run though them. Cheaper to lift coils too. Torsions bars just seem to fatiuge.
Tyler
94 F-250 PSD 5 speed
95 F-150 302 5 speed
Old 07-14-2003, 10:38 AM
WXboy's Avatar
Well, my truck has torsion bars. To be honest, the reason I'm asking is because I'm thinking about buying a new truck. The Ranger still uses torsion bars. In fact, ALL compact trucks I've seen use torsion bars except Toyota. The Tacoma uses coil springs with shocks running through them. I have heard this is why Toyota trucks are so tough off-road, but I just wanted to ask you guys if it's true or not.
Old 07-14-2003, 12:22 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
The F-150's use torsion bars too.
Old 07-14-2003, 02:03 PM
To answer the question I think your asking, coil springs are tougher than torsion bars. Torsion bars are fine for stock rigs staying mostly on road, but if you want to fling them a beating and hammer it off road I'd take a pass on them. But thats just me...
GMC and Chevy: what's the deal with "torsion bars" ? 82_F100_300Six Ford vs The Competition 5 01-02-2017 10:50 PM
Why do pretty much all 4WD trucks have torsion bar front suspension? ghunt General Automotive Discussion 7 01-30-2015 07:54 AM
torsion bars for towing blue924.9 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 2 08-07-2013 04:04 PM
2005 Ford Ranger lift Steven Pickard Ranger & B-Series 1 04-04-2012 09:06 AM
Found a donor and might be ready to order a Gibbons Cordova kit... 54FordF1shortstep 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 11-07-2008 05:03 PM
Tags
2002, bar, bars, coil, coils, f150, ford, ifs, off, rangers, road, spring, springs, torsion
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
