Brock's 69 build
Proceed Mr. Brock Grimes... FTE will be here to help when ye get stuck.
Subscribed.
An E303? That means small block.
M6253A50....roller cam conversion kit.
M6500T58....roller lifters for "non-roller" blocks
I'm told the motor came out of a 94-96 bronco.
Has iron heads (not gt40/p) which will go away when I build the engine.
I'm considering a 351. In the parts book from ford racing is says:
Also fits 1994-1997 351W with factory roller cam when used with mass air EFI.
I picked up the cam super cheap and couldn't pass up the deal.
Still debating the engine but I'm swapping in a 4r70w/4r75w for sure.
Time and cash will tell.
The trucks spec's as it sits.
It's a:
1969 Ford F100 Ranger
302/5.0 from a 94-96 Bronco
Electric Fan
aluminum radiator
Electric fuel pump
Edelbrock intake and Carb
C4 automatic trans.
Ford 9" Rear
Sky Blue originally
The new seat mounting brackets are from a 68 while the bench seat is from a 88.
It's a:
Electric Fan
aluminum radiator
Electric fuel pump
C4 automatic trans.
Ford 9" Rear
Sky Blue originally
