Bolt-on plans. Any suggestions? - Ford Truck Enthusiasts Forums
Old 08-09-2014, 08:42 PM
460 FORD MAN's Avatar
460 FORD MAN 460 FORD MAN is offline
460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.
Intended use: Mud truck, NO street time.
Current set up: D1VE block, D3VE heads, Holley 650, Edelbrock performer intake. Everything else is stock (as far as I know)
Plans: Holley 750, '69-'71 double roller timing chain, recurved distributor, Hedman headers 1.75" primaries 3" collector, 3" glasspack exhaust.
Any suggestions?
Machine work is out of budget right now, it would be nice.
I'm looking to do upgrades that I will be able to use when money allows for machine work so I won't have to swap everything else out again.
Truck is a '79 F150 460, C6, np205, half ton axles 3.50 ratio (getting 5.13's) 35" tires.
Thanks, Brandon.
Old 12-18-2014, 11:08 AM
mikeinmilton mikeinmilton is offline
mikeinmilton is starting off with a positive reputation.
F150 460
I had a truck just like yours with a 1971 429 out of a T-Bird. I had D0VE heads, the block bored .030 and decked with flat top pistons. Double roller chain, L&L fenderwell headers with 3" Flow Master mufflers. Edlebrock intake with a 750 Holley. I called Comp Cams and they recommended a cam that worked well. I used 4.56 gears with 39" tires and lockers in both ends. I ended up getting custom drive shafts for front and rear, if I got some good traction I couldn't keep stock shafts in it. The truck ran very well.
Lifting my 1979 F150 thread, with lots of pics 460 FORD MAN Offroad & 4x4 1133 04-24-2014 11:41 AM
Trucks Gone Wild At Slopoke Mudbog In Eastman Ga 460 FORD MAN Offroad & 4x4 24 10-07-2013 04:55 PM
Richard Petty came to Georgia 460 FORD MAN Offroad & 4x4 5 09-01-2013 01:12 PM
Lifting my 1979 F150 thread, with lots of pics 460 FORD MAN 1973 - 1979 F-100 & Larger F-Series Trucks 405 07-17-2013 02:59 PM
Narrowed front clip 460 FORD MAN 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-10-2013 01:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
