1959? F-250 firetruck/pickup - Ford Truck Enthusiasts Forums
Old 08-09-2014, 08:54 PM
dcyachtdoctor dcyachtdoctor is offline
dcyachtdoctor is starting off with a positive reputation.
I have a 1959 F-250 4x4 cab and chassis, with a home built firetruck body on it. I am in N.E. Wisconsin. I was going to restore this truck, but I have decided to go with something else. I want the truck to go to someone who is trying to keep some of these alive. It has a clean title. It has typical amount of rust for Wisconsin, but still very restorable. I will be posting some pictures in the next few days.
The VIN is F25COK53994
118 M 253 17F AB 04
7400 146 3800 2938
Odometer reads 36806 miles. As far as I Know, it was converted to a firetruck in the early 70's, so I think the mileage is actual. I drove it home about 3 years ago and it got here fine. The four wheel drive, clutch and brakes were all working at the time. I have had it running a few times since then, but didn't move it around because of a flat tire.
If anyone is interested, I would like to find a new home for it within the next month or so. Please pm me for more information.
Old 08-10-2014, 02:45 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by dcyachtdoctor View Post
I have a 1960 F250 Cab & Chassis.
VIN: F25C0K53994 / W.B. 118 / COLOR: M / MODEL: F253 / DATE: 17F / TRANS: AB / AXLE: 04 / MAX GVW LBS: 7400 / CERT NET HP: 146 / RPM: 3800 / DSO: 2938
F25 = F250.
C = 292 2V.
0 = 1960 (If a 9, would be a 1959).
K = Kansas City MO Assembly Plant.
53994 = 1960 Numerical Sequence of Assembly, the trucks specific serial number.
118" Wheelbase.
M = Corinthian White.
F253 = F250 4WD, 7,400 lbs. GVWR.
17F = Assembled June (F) 17, 1960.
AB = No such TRANS code.
04 = Spicer 60 Rear Axle / 4.56-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity.
7,400 lbs. Gross Vehicle Weight Rating.
146 net HP @ 3,800 RPM
2938 = Domestic Special Order number, truck special ordered by original purchaser, not "bought off the lot."
Old 08-10-2014, 08:08 AM
Bill, thanks for your reply. I have attached a picture of the data tag showing the "AB" code. Maybe it is abnormal?!
Old 08-10-2014, 12:48 PM
No AB TRANS code is listed in the 1957/63 truck parts catalog. A by itself is a 3 speed manual, B by itself is the Warner 3 speed manual with Overdrive. Overdrive only available in F100's (2WD).
This truck was originally a Domestic Special Order, which means that something "special" was installed by FoMoCo that was not an RPO (Regular Production Order).
But, since FoMoCo THREW AWAY all the records for these trucks decades ago, there is no way to find out what was "special."
Old 08-12-2014, 06:37 AM
Picked up a C600 2beast Large Truck 4 04-10-2016 05:19 PM
Restoring my crew cab...build thread on the Dastardly Dog HpCowboy13 1973 - 1979 F-100 & Larger F-Series Trucks 187 03-15-2016 08:23 PM
1956 COE MARMON HERRINGTON OPEN CAB FIRE TRUCK RESTO LINK OCDRESTO 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 02-10-2016 07:39 PM
Wisconsin 6.0L head studs HELP!!! shayne.jacques 6.0L Power Stroke Diesel 1 04-01-2015 12:34 AM
Greetings from Oklahoma by way of Wisconsin Blackhorse1155 New Member Introductions 2 12-19-2014 09:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
