Trouble with Wheel Vintiques Gennie Innies - Ford Truck Enthusiasts Forums
Old 08-09-2014, 05:02 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Has anyone else had trouble with fit of innie hubcaps (dog dish) in Gennie Vintique wheels? Neither reproduction nor original hubcaps will fit. It appears that the inner diameter of the wheel at the location of the nubs is too small. My wheels are 15". They are also made in 16,17 1nd 18 inch. I purchased mine thru Summit Racing. The Vintique supplied wheels from Summit do come epoxy primed however the epoxy prime does not appear to be overly thick.
I bought and painted the wheels several years ago and just went to fit up the hubcaps. Anyone had a similar experience?
Old 08-09-2014, 05:28 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Are you talking a matter of millimeters, or is never going to fit? Obviously you'll have to grind on it some, but I'd sure be careful and grind evenly on all four surfaces. And check the fit very frequently while doing so. I have one original wheel with an opening that is just slightly too wide. I had to wrap a strip of electrical tape around the flange of the hubcap in order to tighten it up. You certainly don't want that.
Old 08-09-2014, 08:07 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I've had to grind down the "bumps" to get them to go on without beating the heck out of them. Like Doc says, it's a fine line or they get too loose.
Old 08-09-2014, 08:16 PM
Doc, It feels like more than total paint thickness. I don't look forward to going at my finish paint with a grinder, hence, my question. I could remove material from the hubcaps, however, I would be removing some of the ridge that snaps behind the nubs. As I mentioned in my first post above, the original Ford hubcap has the same problem, so it is not a hubcap problem.
Old 08-09-2014, 08:20 PM
Quote:
Scott, I don't think that it is the "bumps" or nubs, I wish it was.
Old 08-09-2014, 11:12 PM
The inner diameter on the reproduction wheels is definatly smaller than n original Ford wheel. It is difficult to get a precise measurement but I think that the inner diameter of the wheel where the inner rolled edge of the hubcap has to fit is upwards of 1/8" larger on my original Ford wheel compared to the reproduction wheel. The nubs on the original wheel are also more pronounced than on the reproduction wheel. I did remove all of the paint at the contact area on one wheel and it still will not fit.
I can't be the only one on this forum that has used Vintique gennie wheels with dogdish hubcaps!
Old 08-10-2014, 10:07 AM
JPMallory's Avatar
JPMallory JPMallory is offline
JPMallory has a very good reputation on FTE.JPMallory has a very good reputation on FTE.JPMallory has a very good reputation on FTE.
Quote:
I didn't have any issues fitting my hubcaps to my gennies, but my wheels are 16". It could just be a problem with their 15" wheels I guess.
Old 08-10-2014, 05:06 PM
Quote:
Jason,
Thanks for your reply. The stamping of the inner disc would be a different set of dies for the 15 vs 16".
Anyone fit up dog dish caps on 15" Vintiques Gennie wheels?
Old 08-10-2014, 05:13 PM
pintoplumber pintoplumber is offline
pintoplumber has a good reputation on FTE.pintoplumber has a good reputation on FTE.pintoplumber has a good reputation on FTE.
I have them on my 15" wheels that I bought about 13 years ago. You have to smack them on with your hand. Dennis
Old 08-10-2014, 05:14 PM
Truckstops 54's Avatar
Truckstops 54 Truckstops 54 is offline
Truckstops 54 is starting off with a positive reputation.
i'll check mine this week, there still in the box
Old 08-10-2014, 06:03 PM
Quote:
I bought my gennie wheels in 2008 and shame on me, I never did a prepaint fitup and now I find the problem. I purchased mine from Summit Racing and they have a 2 year limit. Unfortunately when doing these trucks a 2 year build would be a miracle for me. In my best days it took at least 3 years. That said I pay for almost no labor and do it myself (the reason for the long schedule).
Old 08-10-2014, 06:04 PM
Quote:
Thanks, I will be interested in what you find. Are they 15's?
Old 08-12-2014, 04:00 PM
Okiedokie's Avatar
Okiedokie Okiedokie is offline
Okiedokie is starting off with a positive reputation.
I have used two sets of those wheels in the past [15"] and never had a problem with repro hubcaps [never used originals]. I can't imagine that they have changed the wheel. Now, it does take a pretty good smack with the palm of your hand to seat them. If you hit the edge of the cap a good firm smack it won't dent the cap [at least mine didn't]. Don't use a mallet. My brother has a couple of F1's with original wheels and he has a problem keeping the repro caps on the wheels.
Old 08-12-2014, 04:20 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
If its real close, would some time in the freezer help?
Old 08-12-2014, 05:49 PM
Wmrdalydvm Wmrdalydvm is offline
Wmrdalydvm is starting off with a positive reputation.
I'm with Jason. I bought 16" gennies, also from Summit and my repro caps fit just fine
Bill
Replacing '66 F260 16 inch 8 lug split rims smitka66 1961 - 1966 F-100 & Larger F-Series Trucks 14 09-08-2016 05:30 PM
Wheel Vintiques Gennies dlb.motorman 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 08-02-2015 06:25 PM
16in wheels / tires Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-24-2014 01:35 PM
Vintique Steering wheel 1967 Sam's1967 1967 - 1972 F-100 & Larger F-Series Trucks 2 06-21-2014 10:41 AM
'innie' wheels GB SISSON 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 03-25-2014 07:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
