Cruise control and turn signals wont work! - Ford Truck Enthusiasts Forums
Old 08-09-2014, 02:29 PM
NIdude NIdude is offline
NIdude is starting off with a positive reputation.
I just bought a 97 Powerstoke 5-speed and the turn signals and cruise control don't work. The indicator arrows for the turn signals don't turn on, there is no clicking noise when you try to use the turn signals, and the turn signal lever doesn't return to the neutral position after you turn. I checked all the lights on the truck and the brake light on the top of the rear of the cab doesn't work and the bulb for the low beams on the drivers side is out.
- Will those two lights have anything to do with it?
- Are there any fuses or switches that I can check that will narrow it down to what I need to replace?
- Any other advice?
The previous owner replaced the steering column right before I bought it cause the lower bearing went out. I'm thinking that maybe he didn't connect something while putting it back.
Old 08-09-2014, 03:14 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
1996 Bronco/F-Series Workshop Manual
Section 17 - electrical
The turn signal switch is called a "Multi Function Switch" and possibly the previous owner did not plug it in while having the column apart. Get the turn signals working first before working on other issues. I'm assuming your brake lights are working.
Old 08-09-2014, 03:21 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
flasher switch can stick sometimes, not on but not all the way off. cycle that switch several times than check turn signals and cruise!
mine did this last week it might have been the first time I have used the flashers. after turning them off the cruise wouldn't work and no turn signals. I cycled the switch several times and all was fine.
Old 08-09-2014, 07:06 PM
Yes the brake lights work. Just not the one on the cab of the truck but I think that's just because the bulb is bad or something easy.
Thanks for the info. Ill check it out.
Old 08-09-2014, 07:22 PM
My window wipers are working correctly. Sense the window wipers and turn signals are all part of the multi function switch, doesn't that mean that the multi function switch is not problem?
Old 08-09-2014, 11:06 PM
helifixer's Avatar
Quote:
no!
it is several switches in one housing.
Old 08-10-2014, 12:00 AM
tractoman's Avatar
tractoman tractoman is offline
tractoman is starting off with a positive reputation.
Check your fuses and I have read the high mounted brake light bulb can cause cruise issues.
Old 08-10-2014, 06:59 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I'd fix that third brake light bulb first. My cruise would kick off when I used the blinkers when mine was burnt out.
Old 08-10-2014, 07:18 AM
ReBilld's Avatar
ReBilld ReBilld is online now
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Yep....the third brake light being burnt out can keep the cruise from working.
turn signal doesn't work when lights are on BigCountry1978 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-02-2016 01:14 AM
Turn signal problem Bradley Ripley 1999 to 2016 Super Duty 1 02-22-2016 11:51 PM
1983 E-150 Turn Signal/Cruise Problem Brok 1968-2013 Full Size Vans 2 09-05-2015 07:48 PM
99 Ford turn signal/dash signal problem cabinman 1999 to 2016 Super Duty 2 10-29-2010 03:01 PM
Turn Signals - sometimes they work, sometimes they don't 1974Ranger 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-02-2010 12:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
