Michigan Chapter Join Chapter, Leader: Toyman
Looking for a 400 in lower Mich.
Old 08-09-2014, 05:03 AM
Bud Mud's Avatar
Bud Mud
Bud Mud is offline
im looking for an old 400 to rebuild in lower mich. My 77 has a 351 now, i want to swap to a 400,i know i can build my 351 into a 400 but i want to be able to drive it while im building a 400 this winter. THANKS
Old 08-19-2014, 02:55 PM
derbydad276's Avatar
derbydad276
derbydad276 is offline
Old 08-20-2014, 10:56 PM
Chad149's Avatar
Chad149
Chad149 is offline
Your sig says 351M, correct me if I'm wrong, but I thought the M shared bell housing pattern with the 429/460 as well? Any reason your not considering that engine?
Old 09-03-2014, 05:40 PM
Bud Mud's Avatar
Bud Mud
Bud Mud is offline
my truck has a 351m, i want to start building a 400 while im driving it. I may go with a 460 but i dont want to revamp my exhaust and anything else comes along. The 351m is not enough,the 400 will do all i want plus not add nose weight.
Old 09-30-2014, 09:09 PM
zx3focus's Avatar
zx3focus
zx3focus is offline
I have a couple. One needs rebuilding and one is on a stand with a fresh short block. HV Melling pump, mild RV cam, bored, Clevite 77 bearings. In west Michigan near Muskegon.
Old 10-03-2014, 12:57 PM
Toyman's Avatar
Toyman
Toyman is offline
I can't imagine the weight being that big a factor, there is only about 150# difference between the 460 and the 400m.
As they say, there is no replacement for displacement........
Old 10-07-2014, 06:39 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
That's why I buy 30 packs.
Old 10-07-2014, 06:43 AM
Toyman's Avatar
Toyman
Toyman is offline
Now if they could just do the 30 packs with the bigger (16oz) pistons in stead of the 12oz ones.....
Old 10-07-2014, 10:05 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
You can get 18 cylinder packs with tall boys... 288 cubic ounce displacement. My 30 cylinder, although smaller pistons displaces 540...
Old 10-07-2014, 10:09 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
Who knew that Chrysler made a http://en.wikipedia.org/wiki/Chrysler_A57_multibank for tanks?
Old 10-07-2014, 11:14 AM
Toyman's Avatar
Toyman
Toyman is offline
That should bolt into a Jeep then, plug and play right?
Old 10-08-2014, 06:29 AM
Bud Mud's Avatar
Bud Mud
Bud Mud is offline
i drag raced for 28yrs,the last 7 in a pro class,weight is everything to me,150lbs is a lot. A mild built 400 can produce as much tqr as a stock 460, built with the right parts a bit more. Ive had smaller NOS engines putting out more HP than some of my lager C.I. (706ci) NOS engines. Displacement is not always the deciding factor.
Old 10-11-2014, 05:01 PM
Toyman's Avatar
Toyman
Toyman is offline
Got a line on a good running 400, cammed, and new Pistons a few years ago. Edelbrock carb.
What's it worth to you? I might be buying the whole bronco
Old 10-12-2014, 04:03 AM
Bud Mud's Avatar
Bud Mud
Bud Mud is offline
what is it worth IYO? If you want me to put a price on it,then hows $100.? Long story short but im suppose to have one coming from ohio, but its been a month so i have no idea. If you are into 460's i may have some stuff that interest you, new moroso rear sump oil pan with pick up thats new,the 2 cost me almost $500.,i have 2 bare blocks one is a cj/scj,the other standard block. Brand new timing chain cast cover that was $100.,and 1 set of heads. I have all part#'s if needed, just want that stuff out of my way.. THANKS Bud
Old 10-12-2014, 04:04 AM
Bud Mud's Avatar
Bud Mud
Bud Mud is offline
sorry i missed your reply,thread kinda got cluttered up. How much for the one that needs rebuilding?
Quick Reply: Looking for a 400 in lower Mich.
