Looking for a 400 in lower Mich. - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
Old 08-09-2014, 06:03 AM
Bud Mud Bud Mud is offline
Bud Mud has a very good reputation on FTE.Bud Mud has a very good reputation on FTE.Bud Mud has a very good reputation on FTE.
im looking for an old 400 to rebuild in lower mich. My 77 has a 351 now, i want to swap to a 400,i know i can build my 351 into a 400 but i want to be able to drive it while im building a 400 this winter. THANKS
Old 08-19-2014, 03:55 PM
derbydad276 derbydad276 is offline
derbydad276 is starting off with a positive reputation.
Old 08-20-2014, 11:56 PM
Chad149's Avatar
Chad149 Chad149 is offline
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
Your sig says 351M, correct me if I'm wrong, but I thought the M shared bell housing pattern with the 429/460 as well? Any reason your not considering that engine?
Old 09-03-2014, 06:40 PM
Quote:
my truck has a 351m, i want to start building a 400 while im driving it. I may go with a 460 but i dont want to revamp my exhaust and anything else comes along. The 351m is not enough,the 400 will do all i want plus not add nose weight.
Old 09-30-2014, 10:09 PM
zx3focus zx3focus is offline
zx3focus is starting off with a positive reputation.
I have a couple. One needs rebuilding and one is on a stand with a fresh short block. HV Melling pump, mild RV cam, bored, Clevite 77 bearings. In west Michigan near Muskegon.
Old 10-03-2014, 01:57 PM
Toyman's Avatar
Toyman Toyman is offline
Michigan Chapter Ldr
Toyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputation
I can't imagine the weight being that big a factor, there is only about 150# difference between the 460 and the 400m.
As they say, there is no replacement for displacement........
Old 10-07-2014, 07:39 AM
SDElwood's Avatar
SDElwood SDElwood is offline
Official BeerMaster #1
SDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputation
Quote:
That's why I buy 30 packs.
Old 10-07-2014, 07:43 AM
Toyman's Avatar
Now if they could just do the 30 packs with the bigger (16oz) pistons in stead of the 12oz ones.....
Old 10-07-2014, 11:05 AM
SDElwood's Avatar
You can get 18 cylinder packs with tall boys... 288 cubic ounce displacement. My 30 cylinder, although smaller pistons displaces 540...
Old 10-07-2014, 11:09 AM
SDElwood's Avatar
Who knew that Chrysler made a
30 cylinder engine 30 cylinder engine
for tanks?
Old 10-07-2014, 12:14 PM
Toyman's Avatar
That should bolt into a Jeep then, plug and play right?
Old 10-08-2014, 07:29 AM
i drag raced for 28yrs,the last 7 in a pro class,weight is everything to me,150lbs is a lot. A mild built 400 can produce as much tqr as a stock 460, built with the right parts a bit more. Ive had smaller NOS engines putting out more HP than some of my lager C.I. (706ci) NOS engines. Displacement is not always the deciding factor.
Old 10-11-2014, 06:01 PM
Toyman's Avatar
Got a line on a good running 400, cammed, and new Pistons a few years ago. Edelbrock carb.
What's it worth to you? I might be buying the whole bronco
Old 10-12-2014, 05:03 AM
what is it worth IYO? If you want me to put a price on it,then hows $100.? Long story short but im suppose to have one coming from ohio, but its been a month so i have no idea. If you are into 460's i may have some stuff that interest you, new moroso rear sump oil pan with pick up thats new,the 2 cost me almost $500.,i have 2 bare blocks one is a cj/scj,the other standard block. Brand new timing chain cast cover that was $100.,and 1 set of heads. I have all part#'s if needed, just want that stuff out of my way.. THANKS Bud
Old 10-12-2014, 05:04 AM
Quote:
sorry i missed your reply,thread kinda got cluttered up. How much for the one that needs rebuilding?
Miracles still happen flyboy2610 Nebraska Chapter 9 11-11-2015 10:27 AM
BUNDY HILL in JEROME, Mich.??? Bud Mud Michigan Chapter 5 01-05-2015 07:42 AM
400 wanted Bud Mud 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 08-15-2014 06:00 PM
Hello all Bud Mud Michigan Chapter 5 05-26-2014 09:00 PM
8 Lug wheels wanted Bud Mud 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-04-2014 09:41 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
rich_is_a_putz
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
