Trozei's '69 F100 Build Thread
#662
Actually I bet while it was sitting in WA all those years it's anti freeze was below par. Cold WA night prolly froze the water in it's cooling jacket. Ice expanded in it. Cracked the block. Freeze plugs a tad too high. While this makes perfect sense it amazes me the pressurized system didn't leak. Built Ford Tough casting must have sealed itself back up.
#663
#666
on
The 300I6 is a strange one for sure. In my shop in 20 years I had
three bad cast blocks. All on the #1 cylinder. It was cast like to thick
and the water pump impeller would hit it. The first one I saw was a new
truck still under warranty. I called Ford and asked what the hell. They
sent me a new block for that one. But the next two Ford had a spacer
plate to go under the water pump to clear # 1. That worked very well.
Anyone ever run into this besides me? Lets hear it guys.
#667
on
I suspect that Jeff is right again, with the low water/antifreeze in the block, and a cold Wa. night, cracking the block like that. I am sitting in San Diego, with a retired machinist, of some renown, and he has never heard of a block cracking, and it not leaking, when the crack was through to the water jacket.. How unique.. Another sign of just how tough that engine is..
Baja
Baja
#668
My new engine should be ready fairly soon. Anyway, I got my stainless engine bolt kit from Classic Inlines and my new valve cover mailed in from Clifford. It's way taller so it can clear roller rockers. Not happy about the casting flash. For 300 some odd dollars I was expecting a little better detailing but that can be dealt with.
#669
#672
#674
Quick trick to clean that up if they arent going to make good on it is to throw it in a blast cabinet with FINE silica beads and blast it. It takes a while to get an even sheen to it... Then squirt it with some high temp clear coat. You can buy it at your local auto parts store. Multiple thin light coats and be patient in the whole process. I do this all the time with intake manifolds.
On a lighter note... Good thread. I just spent the last hour reading it.
#675
Alternatively, get 'er powdercoated, sand the fins, and then powdered with clear gloss.
