Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Old 08-08-2014, 02:45 PM
FordTruckChuck FordTruckChuck is offline
FordTruckChuck is starting off with a positive reputation.
Frontend Clunk
After having all 4 shocks replaced, my truck now has a clunk in the left front area. I'm told it's due to a bad L/F Upper Control Arm Bushing & that to fix it the control arm needs to be replaced. Does this about right? And any suggestions on where to get it? Thanks.
__________________
'98 F150 XLT Super Cab Long Bed 5.4L E4OD 4x4
Old 08-09-2014, 08:03 AM
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
Quote:
It is very possible that is what is the issue....I would check the sway bar end links 1st and then the lower ball joints, then tie rod ends.
If it turns out to be the lower ball joints ...might as well do the Upper control arm too at that time, because you'll have the whole thing tore apart anyway.
Old 08-09-2014, 11:10 AM
rjcorazza rjcorazza is offline
rjcorazza is starting off with a positive reputation.
The word clunk caught my attention, as that is how I described the sound on my right front on a 97 F150. It was the LEFT sway bar link.
Old 08-09-2014, 01:57 PM
Thanks for the input, enriched&beyound & rjcorazza. The links were replaced about a year or 2 ago & still look new. My tech (& friend) is the one who diag'd it so I trust it's the arm bushing. Was just hoping to hear from someone who's been there & done that. The degree to which it's clunking I'm thinking that it would be apparent with a visual inspection. So, I will be getting under there & taking look.
__________________
Old 08-09-2014, 08:45 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a very good reputation on FTE.steve(ill) has a very good reputation on FTE.steve(ill) has a very good reputation on FTE.
YEs, if the bushing mount is bad, you replace the entire control A arm and it will have two new bushings in it... Cost is $75.
__________________
2002 SuperCrew 4 x 4 5.4 XLT -115K miles -NEW
2010 EDGE FWD - V6 ----------40,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
Old 08-09-2014, 11:31 PM
Ok. Thanks, steve.
__________________
Similar Threads
03 Explorer XLT transfer case issues Glue Man Explorer, Sport Trac, Mountaineer & Aviator 3 09-04-2014 10:26 AM
Clunk tommyleea Bronco II 11 06-01-2009 08:57 PM
Pitman arm bushing CPerry 1997 - 2003 F150 16 12-21-2008 11:45 AM
Clunk Clunk in front end stops when brake applied TrevorP 1987 - 1996 F150 & Larger F-Series Trucks 14 01-26-2008 01:23 PM
clunk noise.....radius arm bushings? Mexray 1978 - 1996 Big Bronco 4 04-06-2002 05:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
