I am replaceing the clutch and transmission in my 1989 F-150. this is the first time I have done this and I have no idea what im doing. Is thare someone in the area that could help me? I will pay for your time if need be. Thanks in advance!
Which motor does your truck have? 300-6 or 302 (5.0L) or 351 (5.8L) V-8s
I have found it easier to deal with transmissions in Rangers if you pull the engine, leaving everything in open view and less time grubbing around on the ground.
Easiest scenario, much better than 4wd. Drop the exhaust, drive-shaft, get/rent a trans jack, loosen trans crossmember, remove slave cylinder, remove bell-housing bolts, wires, speedo-cable, remove the trans mount, (support with jack) remove crossmember, slide back and drop trans.........everything is exposed to work on.
