Carburetor issue - Ford Truck Enthusiasts Forums
Carburetor issue
Old 08-08-2014, 02:02 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab 78 & 87 Super Cab is offline
78 & 87 Super Cab has a good reputation on FTE.78 & 87 Super Cab has a good reputation on FTE.
Carburetor issue
While I was warming up the 223 in My '59 to check the generator I put on, when I would press on the gas,it would bog severely, almost to backfiring.
Saw this on the side of My Holley 1 bbl, I assume this is the power valve? Are ones for a 2bbl/4bbl carb the same?
Old 08-08-2014, 02:58 PM
Maltman's Avatar
Maltman Maltman is online now
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
is there any gas coming out of the top vent of carb?
Old 08-08-2014, 04:11 PM
Quote:
I didn't notice anything
Old 08-08-2014, 04:50 PM
Maltman's Avatar
I ask because it looks like the fuel inlet fitting is wet...maybe from fuel, and that could cause many problems
I do not know if spark control valve is same or if that is your problemo, this site and Mikes videos on the you tube are GREAT info and help
Holley 1904 Carburetor Parts
http://www.carburetor-parts.com/Holley-1904_ep_320.html
Old 08-08-2014, 05:57 PM
Damifiknow's Avatar
Damifiknow Damifiknow is online now
Damifiknow is starting off with a positive reputation.
Is the accelerator pump working? Hit throttle while looking into carb and see if gas is squirting from that little screw on the edge of the air inlet. Clear as mud right?
If not prolly the accelerator pump diaphragm inside carb.
Old 08-08-2014, 09:56 PM
Holley 1904
There is a small fitting leak, that is the wet spot you saw in the pic
Old 08-08-2014, 10:07 PM
I'll check that out
Old 08-09-2014, 12:14 PM
Didn't see any gas squirt from that screw, so I pulled the accelerator pump diaphragm out, it wasn't stiff,or looked dried out. Maybe there is a passageway plugged, I guess I'll pull the carb and clean it
Old 08-14-2014, 10:37 AM
Accelerator pump was bad, found one at a carb shop in a nearby town, for $11 bucks. Putting it back together now
Old 08-14-2014, 05:52 PM
Maltman's Avatar
good deal, I also found that on my carb I did not need gaskets on fuel inlet line. I had a copper and fiber gasket and fiber was coming apart and getting needle stuck...
Old 08-15-2014, 04:00 PM
Damifiknow's Avatar
Quote:
Did you file the back of the economizer valve housing flat before you put it back together? My carb leaked like a sieve until I figured out why. Carbs would leak all the gas from the bowls into the engine over night. I filed the mounting surface flat with a file and that solved the problem.
Old 08-15-2014, 04:53 PM
I'll check that before I put it back together
Old 08-20-2014, 02:23 PM
I put the new pump in, and the flat spot was still there. Yesterday for gits and shiggles, I took out the #60 jet, and replaced it with a #67. The flat spot went away, revs up smooth as silk with the choke wide open. I will still check the ignition timing (soon as I can find the marks)
A little progress 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 4 02-21-2015 09:48 PM
Another small problem 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 27 06-05-2014 02:49 PM
What is this? 78 & 87 Super Cab Ranger & B-Series 3 05-20-2014 09:52 PM
Something not right here..... 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 11 05-20-2014 10:14 AM
Interesting mirror 78 & 87 Super Cab 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-29-2013 03:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
