Rear End Oil Help - Page 2 - Ford Truck Enthusiasts Forums
Rear End Oil Help
Old 08-10-2014, 11:35 AM
blupupher's Avatar
blupupher blupupher is offline
blupupher is starting off with a positive reputation.
Yeah, it is a pretty basic mechanical task.
Biggest issue people have is they don't clean the gasket surface correctly or don't apply the gasket maker correctly and end up with leaks.
Also forgetting the Friction modifier can cause issues too if you have factory limited slip.
I have heard of many that even though they use a fluid that says no need to add a FM, they still have chatter from the LS and the only way to fix it was to add the
Ford FM Ford FM
, so I added FM even though the fluid I used said it has FM already.
Most current nav version and where to find it? jake00 2007 - 2014 Expedition & Navigator 1 09-08-2015 12:31 AM
Radio Wiring Diagram Jake86us 1968-2013 Full Size Vans 8 08-30-2014 02:35 PM
D60 and D70 rear ends... pros/cons? mando jake 1973 - 1979 F-100 & Larger F-Series Trucks 21 12-24-2008 11:19 PM
Need some info on a 5-speed tranny out of a 79 f600 mando jake 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-20-2007 10:36 PM
best way to clean hazed plexiglass (windscreen) jake00 General NON-Automotive Conversation 9 07-06-2007 10:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
