Towing performance question and negative boost - Ford Truck Enthusiasts Forums
Old 08-07-2014, 07:04 PM
BryanStein BryanStein is offline
BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.
Late build 2004 F250 about 150k on the engine. 3.73 gears. I've had the truck for a year. Flushed and new radiator immediately after purchase and went with ELC. Saw high deltas (30 degrees unloaded at 65) and put in a new oil cooler. EGR is deleted. My deltas still run about 12 degrees. I can drink out of my coolant system and the oil cooler only has 8k miles on it. So I know my oil cooler is good. I may have a compromised oil cooler bypass valve. I don't worry about it. There's a small aircraft prop in the front of the engine that cools things off well when it kicks on.
I've got a few questions from those experienced enough to know.
1) Towing the 8300 lbs TT at 75mph, I get ECTs of 200-205 and EOTs of 250-256. When it hits 256, the fan gets to 3000 rpm quick and everything cools down. Should I be worried? I don't. It has to be the oil cooler bypass valve. Where is the easiest place to get a replacement? I read about 6 months ago that IH has a kit you can buy for around $100. It has all the valves in it and the kit is hard to find. Anyone know anything about this? This is one of the reasons I run synthetic.
2) Is my performance where it needs to be? I tow at 75 to 80 mph. Seems to do better at 75 pulling hills than at 65 mph. I use Torque Pro. My load is 85 to 98% all the time. Shifts down when climbing hills and maintaining 70 mph. The strange this is that my boost goes from 22 to negative when I'm close to WOT when towing or not. The intake pressure goes to 0.7-2.0 when this happens. It does not seem to hurt anything or drop performance when this happens. The VGT stays around 15% before and after the boost goes negative. I'm around 2200 rpm so I didn't think I wanted the veins to be closed. Is there a harm in letting this continue or should I try and find out what is going on. Are there other possibilities other than the intake pressure sensor or its wiring?
I'm looking to upgrade to a 10 to 11k fifth wheel and want to make sure the truck is up to the task.
Does the above seem normal? Do most owners see similar performance? Does it appear I'm low on power? The truck runs great. Cranks in less than 2 seconds unless it sits for two weeks or so.
Old 08-08-2014, 06:05 PM
How about a bump.
And since nobody replied, can you at least comment on the boost going negative at WOT? Is this normal? Am I on the right track to take a look at the intake pressure sensor?
Old 08-08-2014, 06:11 PM
Money-Pit's Avatar
Money-Pit Money-Pit is offline
Money-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to behold
As far as Torque Pro going negative under high boost....mine did that for a long time at 18 psi I think. TP had an update a couple months ago and it corrected the issue. Have you updated TP lately?
Your EOT of 250 + while towing is too hot. You may have the base plate bypass valve issue like you mentioned. I'd check with Tousley, now called Autonation Whitebear lake. ( I'm trying to get a link, but my tablet doesn't cooperate on this stuff...)
Old 08-08-2014, 08:38 PM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
I am with Money, what you describe does not seem normal. I can't say from experience because I don't tow that heavy, but some on here do tow that much and more. I may only tow up to 6k lbs and the oil temps barely crack 200 deg.
IIRC one guy had to replace the oil cooler cover to solve his issue, so you may be correct about the cooler bypass valve.
Old 08-08-2014, 08:43 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is online now
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
We are towing the rig you see with no problems if we stay out of the mountains. We weigh 20K gcw which is max for the 04. We weighed on certified scale. We have 189K on the clock. We are stock.
Old 08-08-2014, 08:55 PM
jswartz84's Avatar
jswartz84 jswartz84 is online now
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
1847059C46 is Internationals part number for the oil filter base. Sounds like that could be your problem.
Have you pulled the oil filter to take a quick look at the valves in there? Maybe something might be obvious.
Old 08-08-2014, 09:47 PM
Quote:
Originally Posted by CPB1 View Post
I am with Money, what you describe does not seem normal. I can't say from pooexperience because I don't tow that heavy, but some on here do tow that much and more. I may only tow up to 6k lbs and the oil temps barely crack 200 deg.
Thanks for the input guys. Towing 6k and not keeping Eot below 210 is great. How fast do you tow? Are you stock? If not, what upgrades do you have to keep the Eot that low? Thanks again
Old 08-08-2014, 09:48 PM
Quote:
What EOTs do you run and how fast do you tow?
I thought I updated TP about amonth ago. I'll check and see if there is an update.
Old 08-09-2014, 08:12 AM
jsm180 jsm180 is online now
jsm180 has a good reputation on FTE.jsm180 has a good reputation on FTE.
I see 230* max on the oil pulling hills, 200-210 on the flats at 60-65 mph. No way I would pull a 5th wheel 80 mph let alone a TT, I've seen the damage a 60 mph blowout will do.
Old 08-09-2014, 08:50 AM
CPB1's Avatar
Quote:
Just to clarify, my wife does the towing. She tows horses and is very easy on them, never goes more then 65mph.
When I drained and flushed the coolant I stained it through a coffee filter and got zero contaminants.
We run a tow tune, and have an EGR delete, and oversize exhaust. We use T5 10W-30 oil and I add Archoil every other change along with ELC coolant.
FWIW.... some don't recommend using 10W-30 oil when towing.
ECT/EOT Delta silly question microbc 6.0L Power Stroke Diesel 21 07-29-2016 03:37 PM
Cause of coolant temp spike Jays_Truck 6.0L Power Stroke Diesel 12 04-02-2016 11:48 AM
Possible pluged oil cooler or EGR cooler? rocknut 6.0L Power Stroke Diesel 9 12-22-2015 10:02 AM
Turbo refuses to ReLearn BryanStein 6.0L Power Stroke Diesel 15 09-05-2015 07:44 AM
242 EOT while towing. New Oil cooler and oil cooler cap BryanStein 6.0L Power Stroke Diesel 7 08-19-2015 10:48 PM
Tags
boost, ect, eot, intake pressure, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
