88 f150 tranny problem
I have a 88 f150 4x4 automatic with issues
i bought the truck it ran ok for about a week then the transmission dropped all of its fluid. took that tranny out put in tranny number two which never worked , pulled that tranny and got tranny number three which would only go into first and second pulled that tranny and put in tranny
number four which so far is unknown as to its condition as the truck will not start with the keys so my question is how can i start the truck to try out the tranny
[/LEFT][/LEFT][/LEFT]
Sounds like you have natural safety switch issues with trans number 4, jump it at the fender mounted relay if wanna work around for it a minute try it out not get into ignition issues.
What auto trans does it have? what auto trans did it start with if not the same?
Safe to assume all of them have been the "C6" or no?
If C6 was the vac line to the shift modulator good no leaks?
AOD?
TV cable adjusted correctly?
AOD?
8525ford
12-17-2009 09:59 PM
kiddw/85
03-18-2007 05:33 PM
BuickGS
12-10-2006 11:19 PM
f150horse
04-02-2006 03:43 PM
david00f150
03-10-2005 11:43 AM
