Rough idle and bad miss - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-07-2014, 06:58 PM
IBEWNJ351's Avatar
IBEWNJ351 IBEWNJ351 is offline
IBEWNJ351 is starting off with a positive reputation.
On my way home today all of a sudden truck started running really rough, low power and a bad mis at idle. Got home, ran auto enginuity on it and found no codes. Ran cylinder contribution test and got P0263 cylinder 1 contribution/balance fault and P0269 cylinder 3 fault. I ran it a few times and P0275 cylinder 5 came up once also. Ran buzz test and all injectors sound the same. So im not sure, do i have an IDM going bad or and maybe a valve cover harness problem? Any Ideas?
Old 08-07-2014, 07:10 PM
greg_8507 greg_8507 is offline
greg_8507 is starting off with a positive reputation.
Sounds more like valve cover harness to me.
Old 08-07-2014, 07:28 PM
cjgray1974 cjgray1974 is offline
cjgray1974 is gaining momentum as a positive member of FTE.
Let it idle and watch live data on AE
RPM
ICP - Injection control pressure
IPRDC - Injection pressure regulator duty cycle
FIPW - Fuel injector pulse width
let us know what they show
Old 08-07-2014, 08:27 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Did the CEL come on when it started running bad? Strange you don't have a code. Not a lot of things that won't throw a code and cause low power and poor running.
Fuel pressure is one that can do that though. Any knocking sound when this happened?
Old 08-07-2014, 08:43 PM
IBEWNJ351's Avatar
Quote:
RPM
heres the info i got a vid ill up load too
Old 08-07-2014, 08:46 PM
IBEWNJ351's Avatar
nope no CEL. it does have a bit of a knock to it now.
I pulled the pass side valve cover everything checked out connection was good, no signs of burning or arcing.
Old 08-07-2014, 08:58 PM
F350-6's Avatar
A knock is another symptom of low fuel pressure. If you've got a way to check it, do so. If not, slowly drive out to a stretch of road where you can floor it. See if it falls on it's face when you floor it but does decent when you ease it around.
And be sure to check your oil level to rule that out.
Old 08-07-2014, 09:07 PM
Is it reading .33ms while idling? Or is that volts?
Try unplugging the ICP sensor, to the right of the fuel bowl in the drivers side head.
Old 08-07-2014, 09:13 PM
Old 08-08-2014, 05:43 AM
IBEWNJ351's Avatar
I tryed pulling the icp, it didnt make a difference.
I do have a fuel pressure gauge it holds 65 psi pretty steady.
it feels like its down a cylinder or two. Im going to pull the drivers side vavle cover when i get home and check that out. Im kinda stumped on this one
Old 08-08-2014, 12:28 PM
How many miles on the truck? Sounds like mine when it's cold. I have an injector or two that wont fire until oil temp gets above about 140deg.
Old 08-08-2014, 02:37 PM
Tugly's Avatar
Tugly Tugly is online now
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
That FIPW is wrong on so many levels. The last time somebody had all the same symptoms, I think it was the ICP. Pulling the ICP with no change may rule that out, but the FIPW should not be that low for any reason - 0.6 ms is "off" (sync signal), and the solenoids have difficulty operating correctly below about 1.3 ms. If that FIPW is accurate, the truck will run rough - if at all.
What did the FIPW and IPR do when you pulled the ICP connector?
UVCH is suspect.
Old 08-08-2014, 03:07 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
0.31 ms pulse width can't even be right. 3.1 I could believe, but not 0.31. What does it do when driving? What's the max value you see?
Old 08-08-2014, 03:09 PM
IBEWNJ351's Avatar
heres it is with icp unplugged.
windows 7 screen shot
I know for sure now cylinders 1 and 3 are not firing ran the truck for a bit and the exhuast on both of them is still cold, everything else heated up.
Old 08-08-2014, 03:15 PM
IBEWNJ351's Avatar
P0269 Cylinder 4/P0284 Cylinder 8 running a little rough mrm8174 1999 - 2003 7.3L Power Stroke Diesel 9 03-07-2016 04:12 PM
7.3L Surging & Rough idle problem mrjimbov 1999 - 2003 7.3L Power Stroke Diesel 37 01-22-2016 08:42 PM
new AE. now I got questions bcaughhorn 1999 - 2003 7.3L Power Stroke Diesel 44 12-12-2015 11:30 AM
Surging & rough idle mrjimbov 1999 - 2003 7.3L Power Stroke Diesel 8 02-15-2014 08:07 PM
1 injector not spitting oil. CCT balance fault on that cylinder brooksbronco17 1994.5 - 1997 7.3L Power Stroke Diesel 9 04-26-2013 04:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
