66 F250 Project, need ideas - Ford Truck Enthusiasts Forums
Old 08-07-2014, 05:36 PM
bigred66's Avatar
bigred66 bigred66 is offline
bigred66 is starting off with a positive reputation.
I'm going to start working on my 66 soon and I was hoping to get some ideas from you all for the interior. The truck is painted red. Currently the inside of the cab needs paint, some type of covering on the floor, and upholstry work.
-I'm considering painting the inside white. What color do you have yours painted on the inside? Does it match the outside or did you do a different color
-Although I'll do a decent amount of driving off road, i think I'd like to put carpet. Would you recommend buying a pre cut carpet such as something from jc whitney? They seem to have bad reviews but i'm not sure where else to get carpet from and I dont think I'd feel confident enough to try and cut my own
-What did you do for seat work? Did you do buckets, a bench from a newer vehicle, have the factory bench re-upholstered? If you want to put some inside cab pics in this post that'd be great! Thanks in advance
Old 08-07-2014, 11:32 PM
SuperSabre's Avatar
SuperSabre SuperSabre is offline
SuperSabre is gaining momentum as a positive member of FTE.SuperSabre is gaining momentum as a positive member of FTE.
My truck is a '66 F100 (not a 250) Custom Cab, LWB 4 x 2, (formerly) 4 speed, so may not apply to your situation. I'll put up two pictures of it right after I brought it home, as stock, before I restomodded it. You can see the interior is two tone, with the top of the dash mirroring the exterior body color - unless you have the black padded dash. Below the stainless steel (or whatever it is) trim the dash is (or was) a cream color - perhaps Wimbledon White as the hood (and other parts) is/are in the factory two tone paint job. So that's the stock look. I put carpet in my truck. Someone recommended Auto Custom Carpets (ACC) of Birmingham, Alabama to me and I am very pleased with the fit and quality. Remember, there are different floor configurations for our trucks depending on whether they are 3 on the tree or auto trans, 4 speed, or 4 wheel drive, and the 4 x 4 cabs are different to the 4 x 2 cabs in the '66 F250 so be careful. I also put sound deadener under my carpet - and throughout the cab and doors - and it makes a huge change for the better. I highly recommend it. You can get a good quality reproduction of your stock upholstery from SMS in Oregon. Good luck with whatever you decide to do.
First Thread. Frankienstein 85 Vanlan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 11-02-2015 07:38 PM
91 F150 XLT Split Bench to Captains Chairs Swap ng19delta 1987 - 1996 F150 & Larger F-Series Trucks 7 07-14-2015 07:12 AM
Next step in truck restoration Melnickta 1961 - 1966 F-100 & Larger F-Series Trucks 7 04-13-2015 10:03 PM
buying carpet lilrobo 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 08-22-2013 10:43 AM
Need suggestions on cab flooring 79F150Seattle 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-09-2011 12:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
