I have a 1994 ford bronco with a 5.0l automatic. I just attempted to put it on a computer to find out what the code is on my check engine light and the computer didnt even register. Could you please let me know how this can be fixed?
Welcome to FTE, Your Bronco is a 1994 and I do believe its an obd 1 system . Your computer is in the bronco and what your using to find the codes is a scanner. Are you sure your scanner is obd 1 compatible ? obd 2 will not work on that year bronco. What symptoms are you having with your truck. TR
x3 I specifically bought a OBD I and OBD II code reader. I went to auto zone, O Reilly and pep boys and only found one code reader for both. My 1994 Bronco is My only OBD I vehical.....
