computer problems - Ford Truck Enthusiasts Forums
computer problems
Old 08-07-2014, 05:30 PM
muddigger1 muddigger1 is offline
muddigger1 is starting off with a positive reputation.
computer problems
I have a 1994 ford bronco with a 5.0l automatic. I just attempted to put it on a computer to find out what the code is on my check engine light and the computer didnt even register. Could you please let me know how this can be fixed?
Old 08-07-2014, 06:16 PM
Black Ford XLT's Avatar
Black Ford XLT Black Ford XLT is offline
Black Ford XLT is starting off with a positive reputation.
Welcome to FTE, Your Bronco is a 1994 and I do believe its an obd 1 system . Your computer is in the bronco and what your using to find the codes is a scanner. Are you sure your scanner is obd 1 compatible ? obd 2 will not work on that year bronco. What symptoms are you having with your truck. TR
Old 08-07-2014, 10:00 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
X2... what were you using to check for codes?
Old 08-08-2014, 02:35 AM
jasoncarpenter1's Avatar
jasoncarpenter1 jasoncarpenter1 is offline
jasoncarpenter1 is gaining momentum as a positive member of FTE.
x3 I specifically bought a OBD I and OBD II code reader. I went to auto zone, O Reilly and pep boys and only found one code reader for both. My 1994 Bronco is My only OBD I vehical.....
Old 08-10-2014, 12:58 PM
jowens1126 jowens1126 is offline
jowens1126 is starting off with a positive reputation.
just ground the self test input to the battery and count the flashes of the check engine light.
If that doesnt work, you could have a bad EEC, which would explain your problems.
Ive seen at least a dozen 94 EEC's go out in the last few months, including 2 of mine.
Computer/trans/TC issue lawdawg79 1999 to 2016 Super Duty 25 08-12-2015 06:25 PM
C6 rebuild Nathan Cox 1987 - 1996 F150 & Larger F-Series Trucks 10 07-31-2015 01:35 PM
94 computer in a 95 junkyardjeff 1987 - 1996 F150 & Larger F-Series Trucks 3 03-25-2015 07:52 PM
04 COMPUTER LOCATION? key pad code SOLOLUCKY 1999 to 2016 Super Duty 6 03-05-2015 06:58 AM
Any Computer Savvy Folks Present? r___r General NON-Automotive Conversation 6 08-23-2014 05:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
